Boss Rc 30
Started by CVS, February 26, 2018, 06:27:52 AM
CVS
I have been using a Boss Rc 30 Looper for years with no problems. Recently the rhythm part (percussion sounds) of the track has been fading out intermittently when I play the loop back. The sound of the 2 tracks is perfect. It is only the rhythm sound that fades in and out. I ran the unit on fresh batteries and via electrical power and the problem occurs either way. It is very intermittent, sometimes you can run a loop for 10 minutes and everything is fine. At other times the fade out will last for anywhere from 5 seconds to 45 seconds and then the proper level of sound returns.
Any input would be appreciated. BTW - I also have a second RC 30 and also an RC 300 and neither of these 2 loopers have this issue.
