VG-88 - INPUT ROUTING
Started by sj1, January 18, 2017, 08:30:51 AM
sj1
Hi,
Working with my recently acquired VG-88 v2 (and GK3), I'm trying to understand if there is or is not a way to have the magnetic PU routed to one kind of distortion (e.g. a dialied-up amp simulator) and the hex PU routed to another kind of distortion (e.g. a stomp box).
Put another way, can the mag and the hex PU signals each follow a separate path for some # of steps before being joined?
sj1
Hi,
In VG-88 v2, is there any way to set up a chain so that the hex PU is at the start of the chain and the mag PU is mixed in later/after?
It seems like the mag PU is locked to the start of the chain and I'd really like to put the hex PU at the start of the chain if possible.
I don't think you can ,if I remember correctly
Fastest method to understand the VG-88 routing is download the VG-88 "VEDITOR" editor
https://www.vguitarforums.com/smf/index.php?topic=6455.0
