GR-30 9v power
Started by Headless68, June 24, 2015, 05:56:08 AM
Headless68
I noticed from the manual that the GR-30 PSI is 9v  - Does this mean it will power up ok using a pedal board power supply or will it need the dedicated roland PSU ?
Headless
Headless68
The GR-30 draws 440mA , so be mindful of the total current load on your power supply, and the current draw of your other effects.
You should be OK with the one you linked above - - but which looper  are you considering?
UK Plug ~ 2,000 mA  9v –ve Polarity FX Pedal Power Supply Unit
Headless68
ok - should be ok then it says its 2000 total  - 500 per cable  & I only need to run the two things which will only be about a third of the total loading - I was more worried that there may be something unique to the roland PSU to watch out for
the 1996 GR-300 was created back when efficient "switching" power supplies cost more money  - thus the warning not to use the old Boss ACA /PSA supplies - as those lacked the higher current of today's supplies.
ROLAND PSB-120 AC Power Adapter w/ Cord (PSB-1U Equivalent - Replaces: ACB-120, ACF-120, ACK-120, ACI-120)
http://shop.rolandus.com/p/ac-adapter-psb-1u-equivalent-replaces-acb-120-acf-120-ack-120-aci-120
http://proav.roland.com/products/psb-1u/features/
So it's 9 volt DC output, just check the polarity connected to the ground on the GR-30 output jacks and the looper if running both from a common supply
(negative ground vs positive ground)
GR-30 DC input jack is Negative Centre (tip) Positive outer (sleeve)..
My original (240 volt here) power supply unit was ACF-240A  ..500mA
HTH
Peter
Headless68
That matches the one I was looking at then so safe to go ahead - Thanks again all
Headless
You're welcome...
...and welcome to GR-30 World... ;D
..no home should be without one...(or two..)... ;)
