Katana - Possible to store to Bank 2, using Panel effects from Bank 1?
Started by AndrewH13, January 08, 2018, 11:51:48 AM
AndrewH13
Hi, new Katana owner here. I have stored 4 pre-set sounds I want on bank A and can access from GA-FC. I have checked that if I want to amend a pre-set with just a tweak, I can make the change to that individual knob or effect and the rest of the panel is ignored and I can re-save to another slot.
But I'm now trying to save to positions 5-8, using effects that were on Bank A such as Chorus. Is it possible to store a pre-set that uses Bank A effects, as when I hold down Panel for a second to try and save to Bank B, amp switches to bank B Channels and Effects?
I know that effects can be substituted using Tone software, but using Effects as in place, can you only save a pre-set with Bank B effects into slots 5-8?  The version 2 manual supplement doesn't cover saving to Bank B.
Hope that makes sense! Any help appreciated.
joeshmoe69
Its easy with the Boss tone studio.
When you are on a preset you like hit the write button on the tone studio
and it will ask you what preset channel you want to save it in.
I dont  know if you can do that without the tone studio.
Jimmy
AndrewH13
Thanks Jimmy, yes after finding no way on unit, I went into Tone Studio and realised how good it is to switch things, so will have to bring Head downstairs to PC, cheers.
