GR-55 Bass - Have a Cigar - Pink Floyd
Started by gumtown, May 09, 2018, 05:11:49 AM
Thought it was about time to post some more patches for bass use..
This one is for playing a Pink Floyd song "Have a Cigar"
First and foremost is the Normal Pickup bass tone, not much effect, just direct, as my GR-55 has a loop to use an analog preamp.
Modelled tone is a Jazz Bass running through a clean JC-120 preamp with bass cut, then run through the MOD Phaser effect, just for a slight background effect.
Synth PCM 2 mixes in half way through the EXP pedal travel for the slight organ tone mixed in.
Synth 1 mixes in at 100/127 travel for the brass/string lead synth which follows the bass, and at the end of the EXP travel, the last note holds while playing other bass sits.
This is done by increasing the reverb time on Synth 1 to 10.0 seconds, and switching on MFX using the CTL DELAY and another assign sets the delay feedback to 98%, and yet another assign switches off the PCM tone to prevent it playing more notes on hold.
