Setting up for graph tech
Started by jimthim, November 30, 2017, 04:01:05 AM
jimthim
I'm going to revamp and remove the Roland GK-3 and replace with a graph tech midi system onboard. I'm confused by the different combinations of midi set ups. I'm going to place all electronics onboard but not sure what to purchase, the complete set up or not everything. It will go a GR 55.
Read these threads and follow the path that meets with your goals
Which one is better - Piezo or Magnetic hex PU?
https://www.vguitarforums.com/smf/index.php?topic=5043.0
Graphtech Ghost Details
https://www.vguitarforums.com/smf/index.php?topic=498.0
GuitarBuilder
Quote from: jimthim on November 30, 2017, 04:01:05 AM
I don't think you'll be pleased with the result.  Graph Tech is the least desirable option, with Roland GK the best; if you're talking about removing an external GK-3, consider installing the internal GK kit instead.
