Connecting Guitar Amp to Audio Interface.
Started by pacemaker1000, January 11, 2018, 09:14:08 AM
pacemaker1000
How do you connect to an Amp?
My particular interface only has stereo rca or headphones out so is this possible?
Can you connect the interface to the effects out and say headphones to the in?
Currently just connect to the Amp aux in but would like to plug Guitar into the normal Amp in and have the interface in just the effects loop if possible.
This would be purely to use Guitar effects available via BiasFX etc and I expect to have to turn any Amp modelling off
I notice the line 6 sonic port has a 1/4 inch dedicated amp in
Can you just use an RCA to 1/4 cable or is an impedance issue?
What is your specific Amp Make / Model?
What is your specific audio interface Make / Model?
What is your specific Computer Make / Model / Operating System?
If you seek best hardware for BIAS AMP /BIAS FX ?
What is your platform?
IOS or macOS or Windows
What is your budget?
each have different answers
Best to review this thread if working with iPad  / iPhone
IOS: Connecting USB Class Compliant MIDI / Audio (Battery Power)
Kevin M
It's probably best to use a good microphone to capture your amp.
pacemaker1000
Toying with the idea of using something like biasfx just as an effects pedal without the cabinet emulator.
So Guitar into amp then in and out through effects loop with 1/4 inch jacks with iPad interface like sonic port/ Irig etc. Could then add delays etc
