Roland gk kit question
Started by Nestoraramio, November 06, 2017, 04:06:06 PM
Nestoraramio
Hello, I would like to install a GK kit and I have the following question: I do not need neither the switch, not volume pot not s1 s2 switches, I just need pickup and output running at volume full, I want to work for different routes the GK and magnetic pickups and switchear with Foot controllers. When installing, if I do not connect these elements on the preamp board will work the same?
Thanks and sorry for my english
Nestoraramio
Hi thanks for the replay i read the posts but i still have the dude.Please check this diagram,the question if i can install only the things that drawned.
https://ibb.co/eWd2vw
Thank you, and  apologise for any inconvenience
Read this whole thread
Help -How to leave out GK Volume, S1/S2 and the Select switch
https://www.vguitarforums.com/smf/index.php?topic=17723.msg126254#msg126254
To the internal kit PCB
Connect the GK PU
Connect the GK Output Jack two ribbon cables
Jump across the CN7 GK VOL connector as explained above
"If you are using a Roland GK-KIT-GT3 Internal kit - Locate white 3 pin connector CN7, and solder a wire between Pin #1 and Pin #2 - where  the VR1 50K Linear Pot (GK-VOL) typically connects. This is equivalent to having the GK-VOL pot on "10" (Max Volume)".
Done.
read more details here
Internal GK-KIT-GT3 Installation questions
https://www.vguitarforums.com/smf/index.php?topic=133.0
Escurridizo
A lot of thanks,this is that I need.Thanks
