GR-55 - Writers Challenge Nov 2015: Flute/Sitar 02 presets or ANY V guitars
Started by DreamTheory, November 09, 2015, 05:44:50 AM
DreamTheory
SUBJECT    GR-55 - Writers Challenge 5: For November 2015
The Pitch: OK guys! Surely all of you have tried playing flute and sitar by now. These would have to be one of the first things you do when you get into guitar to MIDI. Not a GR-55 player? That's OK, use your favorite soft synth flute or sitar.
The Challenge:
1.  One or more of the three factory preset patches must be used (if you are a GR-55 player).
2.  It can be modified but must retain at least 1 of the original PCM tones -but that tone can be modified thru it's parameters.
3.  Drum/percussion tracks, if desired, may be used from any source in the recording. Other instrumentation (such as bass part or synth pads) is also OK, but must be part of your patch modification (hint: use an assign to switch on the tone you need).
4. Please post a copyright free MP3. 3 1/2 minutes or less.
MONTH OF SEPTEMBER 2015 CATEGORIES:
LEAD:     patch 02-2 Flute Solo
RHYTHM: patch 02-2 POLY SITAR
OTHER:   patch 02-2 Dark Side of the Sun
