9Labs - Vectorscope (IOS)
Started by Elantric, January 04, 2018, 10:53:46 AM
https://9labs.io/Vectorscope
Vectorscope
Polar and Lissajous vectorscope for iPad
PRODUCT DESCRIPTION
Vectorscope is the perfect tool to analyze your stereo material. Whether you are a producer, mixer, recording artist, or student, we believe that Vectorscope will soon become an indispensable tool for all your stereo audio needs!
Vectorscope accepts audio coming either from an external iOS-compatible audio device or from an Audiobus-compatible app. Choosing one mode or the other couldn't be easier: When the app is connected to Audiobus, the audio will be routed automatically through it, otherwise the chosen audio source will be external — that simple!
APPLICATIONS
Identifying issues in the stereo image
Checking phase and stereo balance issues
Calibrating preamp, compressor, EQ, and other external processors' gains for optimal stereo recording, mixing, etc.
Stereo metering featuring peak, RMS, peak hold, and max peak readings
And much more!
INTENDED AUDIENCE
DAW producers, mixers, recording artists, etc.
As an educational tool for audio engineering students
All kinds of Audiobus addicts!
USAGE MODES
EXTERNAL AUDIO INPUT MODE
External Audio Input
AUDIOBUS FILTER MODE
As an Audiobus filter
MAIN FEATURES
Polar and Lissajous plotting
Stereo metering with RMS, peak, peak hold, and max peak readings
Stereo balance meter
Phase correlation meter
Autoscale or manual zoom (1x-8x)
Adjustable scope fading rate
5 color schemes
External audio and Audiobus input
Total parameter recall
Hi-res Retina graphics!
https://itunes.apple.com/us/app/vectorscope/id735257507?mt=8
