Midi Snake
Started by whippinpost91850, February 03, 2012, 01:45:00 PM
I want to put together a snake with 2 MIDI cables, a LO-Impedence cable, and a AC power cable. Anyone know how to shield the Midi and Mic cable from the AC cable??. Thanks Paul. I know Proco makes ac/inst snakes , but not like I want
And to whoever posted about the Monster (snake maker)cord wrap, Thanks it works great
You will want to keep the AC power far away from the other cables. If you run them in parallel, you will get 50/60Hz hum injected into your audio.
i found this cable to work for 90% of my "MIDI Snake" pedal board needs:
Ebay Item # 320647513024
http://www.ebay.com/itm/ALESIS-SNAKE-DRUM-10-FEET-4-DIN-4-STEREO-4-DIN-4-S-/320647513024?pt=LH_DefaultDomain_0&hash=item4aa814c3c0
See also this thread:
[https://www.vguitarforums.com/smf/index.php?topic=1369.msg7253#msg7253
You could run power through a multicable, but not the AC side, but the DC side. I have implemented this and have no problems with hum.
ecca
For some reason I cant pull up the thread you linked to.
ecca
Go to ebay and search on this number.    230739065113
Where are you ?
Sixlight I could not open the thread you posted????
ecca
paults
Do a USA ebay search for:
12/3 Cond M27500 SHIELDED Cable BLACK $1 buy 1Ft
or
16/3 Cond M27500 SHIELDED Cable BLACK 1000FT $1 buy 2Ft
16/3 is sufficient in the 20 to 30 foot range, unless you are using it for large power amps.
Here's the link to my snake again. Still of great use and gives a very tidy setup:
