VG-88 - V-EDITOR 0.51 DEMO MOVIE
Started by billbax, July 02, 2012, 11:04:15 AM
billbax
Hi Everyone,
Perhaps some of you have already viewed my VG-88 V-Editor demo from 2005...maybe not.  I still think the VG-88 is a great piece of kit, and certainly would not give it up easily.  No breakout box plug/promo intended...well...maybe...only one day a week.
VG-88 + V-EDITOR 0.51
Thanks,
Bill
www.separate-strings.co.uk
Kevin M
Just picked up a used VG88 and installed the editor this weekend!  Looking forward to finding some time to using the editor.
Just be advised that V-Editor works ONLY with VG-88's that have already been updated to "Version 2.0 firmware.
Older VG-88 firmware had different features and data structure.
billbax
Hi Kmaus10,
Congratulations on the VG-88 8)  The VG-88 has excellent pickup models, body types and effects. Although I am a bit disappointed with the amps and cabs.  Saying that, I have a GR-55 and recently had to resort to using the VG-88 vari-guitar to 'nail' a particular tone and feel.
Elantric, thanks for the link with the V-Editor download...silly me I forgot.  Also you're right about the V2 update (I have the update files and service manual procedure). It's tricky stuff and I remember quite a few people got the VG-88 V2 update wrong.  Dead VG-88, back to Roland, and a bad experience alround.
Bill
thanhlamguitar
#5
Hello! I'm a new member of VGuitar forums and I have a Roland VG-88 (Firmware V 1.0) Could you share me an upgrade file (Roland VG-88 V2)? Thank you so much!
billbax
Hi thanhlamguitar,
Ah the update from version 1 to version 2.  I have the files somewhere, although it's tricky stuff doing the update, and you might be better off having Roland do it.
I have the service manual and unless you are methodically minded, you might be heading for a dead VG-88. Wouldn't sleep easy knowing I've helped trash someone's gear.
Saying that, if you're made of sterner stuff and have some degree of methodology, then we can process.  Elantric, your important 2nd opinion please...cheers!
Bill
Kevin M
Quote from: billbax on November 17, 2012, 09:38:01 AM
Hi thanhlamguitar,
Bill
Elantric's opinion...
https://www.vguitarforums.com/smf/index.php?topic=5250.0
JohnPele
Chaps,
I've used the editors succesfully in the past. However, now that i try them all up or down loads fail ... guessing it's down to now using Windows 7 ... have tried compatability setting back to Win98 and Win95 still no joy.
Have you got any ideas how i can backup my VG88 and load new presets to it or a current VG88 Editor that works with Windows 7
VMWare Player running Win XP Virtual Machine
Or old laptop running Win 98 - the original intended environment along with  a working MIDI Interface.
JohnPele
cheers for this .... VM seems a good idea
Kevin M
I've used the VG88 editor with Win7....seems to work just fine.
JohnPele
That's interesting and good to know ..... what version are you using and were did you download it ... perhaps mine's slightly different
thanks
JohnPele
I'll give it a go .... appreciated ta
mignolyx
Please, dear Elantric,
a little help for me.
I got VG-88 V2
I'm trying to use the editor you had but (on Win 10 pc)
I decompress the zip file, let run the executable, it works for a session and then
it never starts again.
It happened since tonight and please, let me know if you got some solutions.
(i've tried every backward compatibility version in Win 10 but it doesn't works
Quote from: mignolyx on October 28, 2021, 05:37:08 PM
I got VG-88 V2
Im still on Win 8.1  - perhaps someone with Win10 can reply
Quote from: gumtown on October 29, 2021, 07:19:27 PM
Have you tried a "right click" on the app icon and select "Run as Administrator".
Also right click on the EXE file and see if you can run with "integrated graphics processor,  and not an NVIDIA
Also you will find "Troubleshoot compatibility" choice via a right click
But mine runs fine using default settings, but run as Administrator on Win8.1 64 Version   6.3.9600 Build 9600
use a Roland UM-ONE MKII USB to 5 pin MIDi adapter
Discovered the current contact link for Ralph Benchetrit
VG-88 VEdit Source code is now published here
https://github.com/ralphdov/V-editor
