Direct to PA signal with Preamp in the FX loop
Started by olisurf, February 10, 2022, 04:51:14 AM
olisurf
I found out that when you switch off all amp in Gt the output emulations are all switched off. So when you want your own preamp etc in the effects loop and go direct to PA or FRFR box you wont get a good result. The solution for me was to have effect loop in channel A one preamp from GT in channel B both on and then divider to both and mixer 1000% channel A 0% channel B. Now you can go with all cam sims in the output to recording set.
You can hear the differences clearly when you switch off the Gt pream while playing.
