Gt1000core midi clock sync issue
Started by Straker, December 30, 2021, 02:18:19 PM
Straker
Hallo I am a new Gt1000core user.
how do I slave the Boss gt1000core to the midi clock of an Mpc Live?
I went to gt1000core menu, system, midi and enabled clock midi (auto).
The Mpc is sending the clock because if I connect a Boss looper Rc202 it syncs perfectly and also starts playing as I push play on Mpc.
If I connect the trs midi on the same Mpc midi port to Gt1000core midi in with clock midi (auto) enabled, nothing happens.
I tried to enable and disable omni, I tried changing midi channel, nothing happens.
What am I missing?
kineticfx
Are you certain you have the correct TRS midi adaptor?
https://minimidi.world/
Straker
Quote from: kineticfx on January 02, 2022, 06:25:33 AM
I solved it.
Boss sells his Bmidi trs cable which actually is a "Type A" cable. I don't know why they called Bmidi if it's a type A, making just confusion.
So my type B was not working.
Now I bought a type A and all goes fine.
