GT-001- Tube screamer problem
Started by Roy Eades, December 19, 2021, 09:31:45 AM
Roy Eades
Got a good sound using the floorboard app using the tube screamer pedal .Everything fine except when trying to record to audacity daw it just would not record even though it came through the headphones fine.Tried other sounds and they record ok,just don't understand it?
Install ASIO driver. Record with Reaper
Roy Eades
Thanks solved the problem Reaper is way out in front of Audacity
Roy Eades
Just to add to my last post ,had trouble installing ASIO driver with win 10 ,kept coming back with gt001 driver .What I had to do was call up the device manager then click on view at the top ,than click on. Show hidden devices ,this made visible hidden gt001 drivers which I then deleted and then I could link up the ASIO driver to Reaper.
