Fender Rumble 100 with Beyma speaker FRFR
Started by bosetuno, December 16, 2021, 11:57:52 PM
bosetuno
Hi! I just want to share with you this.
I´ve been using this amp from mid 2020 in all my rehearsals with very good results IMHO. I was looking for a lightweight amp with a 12 inch speaker. I considered two amps, the Fender Rumble 100 and the DV Mark Jazz 12. I found a used Fender Rumble 100 at a reasonable price and then got it. The amp by itself is a really good jazz guitar amp (i miss reverb tough, which de DV Mark Jazz 12 has). I replaced the original speaker with a beyma 12GA50 full range speaker, and I got excellent FRFR sound at loud rehearsal volume. The Beyma add some weight but still way under 12Kg. Nice combo!
https://www.fender.com/es-AD/bass-amplifiers/contemporary-digital/rumble-100/2370406900.html
https://www.beyma.com/productos/c/full-range/112GA508/altavoz-12ga50-8-oh/
The Beyma 12GA50 is a inexpensive full range 12¨ speaker with 100db sensitivity and massive 250wRMS (500w program!). Actually I´m also using it in 2x12 enclosures for PA systems with a 3kW power amp. Simplicity at its best, no horn nor filter needed
