Hacking ready made USB cables/sockets - save yourself an hour or so.
Started by philjynx, December 11, 2021, 11:10:24 AM
philjynx
Yep, I did it again, using the line socket of a ready made USB extension cable as part of a 'run/program' switch for my Midi controller, I assumed the manufacturer had used the standard colour-pin mapping.
'A USB device has malfunctioned' was the cheery message I got from Windows when I tested it.
Of course, at first I was chasing bad soldering.
Turns out, on this particular cable the manufacturer had swapped D+  and D- (green and white).
All sorted now and no harm (apart from some wasted time) done.
The really annoying thing is that this is the second time I've been through this; aren't we supposed to learn from our mistakes?
Note: as an extension cable it worked fine as the 'D's were correctly connected end to end, just with the wrong colours.
