Valeton GP-200 MFX / CAB IR / FX Loop
Started by admin, December 05, 2021, 11:07:20 AM
http://zh.valeton.net/home.html
Access switches for :
PRE, WAH, DST. AMP, NR, CAB, EQ, MOD, DLY, REV, OUT
L-R
EXP/FS - INPUT- Aux In-  FX Return-FX Send, Out L(mono),  Out R,  Ground Lift, XLR Out L, XLR Out R, Headphone Out,  MIDI In, MIDI Out/Thru, USB, Power on/off, 9VDC Power Input.
Valeton is sister brand to Hotone Ampero
IMHO this appears has many desired features - 8 footswitches, MIDI I/O , FX Loop , XLR Out and 1/4" Outputs , Aux Input, Built in Expression pedal , 24 bit Audio I/O -
we await more details - may not arrive in USA until April 2022
Use Google Chrome translator
http://zh.valeton.net/GP-200.html
Product Features
● The new digital platform is equipped with high-definition digital modeling technology to create higher quality sound
● 24-bit/44.1kHz high sampling rate
● More than 240 high-quality effects based on high-definition digital modeling technology
● More than 140 legendary guitar/bass/acoustic guitar preamps and IR cabinets
● More than 100 dynamic/distortion/frequency/modulation/delay/reverb effects
● Support storage of 20 user IRs
● 256 preset positions (100 factory presets, 156 user presets)
● 11 modules in the effect chain can be used at the same time, and the order can be set freely
● Phrase loop function that can record up to 180 seconds
● 100 high-quality drum machine rhythm patterns
●Accurate and sensitive visual tuning table
●The 4.3-inch high-definition LCD display presents an intuitive and friendly multi-language human-computer interaction interface
●8 custom function foot nails with light and 3 types of foot nail templates, flexibly switch between different usage scenarios
●Smooth-feeling expression pedal, which can control up to 3 effect parameters
●Rich shortcut buttons and knobs provide more efficient control
●Multiple interfaces meet the use of different environments
● USB Type-C interface provides sound card function, supports Win/Mac/iOS/Android multiple operating systems
●Concise and easy-to-use Win/Mac supporting editing software
●Sturdy and durable metal shell
●9V DC power supply
Specifications
A/D/A conversion: 24-bit high performance
Sampling rate: 44.1kHz
Signal to noise ratio: 110dB
Effect modules: use up to 11 at the same time
Number of presets: 256 preset positions, 100 out-of-box presets
Phrase looper maximum recording time: 180 seconds
Built-in machine: 100 rhythm patterns
MIDI (IN/OUT/THRU): 5-pin standard MIDI interface
Analog input connection
Guitar input: 1/4 "unbalanced input (TS)
Input impedance: 1MOhms (acoustic guitar)
4.7M Ohms (electric guitar)
10k Ohms (Linear input)
Return input: 1/4″ unbalanced input (TS)
Return input impedance: 100kOhms
Aux input: 1/8 "stereo input (TRS)
Aux input impedance: 10kOhms
Analog output connection
Left and right unbalanced output: 1/4″TS interface
Left and right unbalanced output impedance: 1kOhms
Left and right balance output: XLR interface
Left and right balanced output impedance: 1kOhms
Send output: 1/4 "unbalanced output (TS)
Send output impedance: 1kOhms
Headphone output: 1/8 "stereo output (TRS)
Headphone output impedance: 22Ohms
Digital connection
USB interface: USB2.0 Type-C interface
USB recording specifications
Sampling frequency: 44.1kHz
Sampling depth: 16 bits or 24 bits
Dimensions: 345mm (length) × 220mm (width) × 62.5mm (height)
Weight: 2.37kg
Power supply requirements: DC9V, 1000mA
yotarzan
It has polyphonic shifter!!
Looking forward for a demo of that
jwoertz
#9
Looks like the foot switch customization is extremely poor. You can't change switch colors or names. Also in Stomp Mode, you cannot see WHAT the switches are changing. It just says CTRL-1 / CTRL-2 / CTRL-3 / CTRL-4. The switches all stay on (bright) at this time too (Valeton says a fix is coming). And finally no gapless preset switching and no reverb or delay trails between presets. Bad!
mchad
Received mine yesterday after Ebay offered one of those attractive discount offers.
And it ain't too bad actually.
Nice cleans. Pushed and dirty amps need work. Lots of amps too which is cool.
The effects are mostly ok. Vanilla but there's a good selection.
Nice editing app.
All up, it's a decent sounding package that makes you want to work to tweak it in.
It will keep me occupied until something else comes along. And that, is intended to be, the last amp modeler/multi-effect I buy for quite a while.
