Ampero II Stomp Firmware
Started by admin, November 11, 2021, 03:57:43 PM
New firmware V1.0.2 and Stomp App V1.0.1 up -see bottom of Hotone Ampero II Stomp page
http://www.hotoneaudio.com/products/multi-effect/new/ampero-ii-stomp
Ampero II Stomp
Firmware Release Note
Version 1.0.2
Released 1/12/2022
Improvements, Changes & Bug Fixes
Optimized system performance
Optimized I/O meter accuracy
Optimized volume knob for smoother volume control
Now when connecting to any input/output jack, the corresponding I/O meter frame will light up to indicate connection
USB audio output level is lower than normal – FIXED
Abnormal effects/effect parameters fixed: Behemoth M, Moo VCF Env, Chili Wah, Match 30 Clean (AMP/PRE AMP), Emperor Drive (AMP/PRE AMP), Messe Bass 400 (AMP/PRE AMP), Tape Delay M, Tape Delay S, Reverse Delay, 2290 Mod, 2290 Ducker
When controlling some parameters by an external expression pedal, in some cases, parameter value display and actual effect sound don't match – FIXED
When switching Trail switch on/off repeatedly, system overload message may occur – FIXED
In Global EQ menu, switching some frequency band switch on/off repeatedly may cause unit output clip – FIXED
Other minor bug fixes
Version 1.0.1
Released 11/10/2021
Optimized overall hardware stability
When controlling some parameters by an external expression pedal, in some cases, expression range cannot be set properly – FIXED
When switching Sync switch on/off of time-based effects, in some cases, time-based parameter range may go wrong – FIXED
Fixed prompt typos
Version 1.0.0
Released 11/5/2021
Initial Release
http://www.hotoneaudio.com/support/2
Ampero II Stomp Firmware Release Note
Version V1.0.1
Released 11/11/2021
1.   Optimized overall hardware stability
2.   When controlling some parameters by external expression pedal, in some cases, expression range cannot be set properly – FIXED
3.   When switching Sync switch on/off of time-based effects, in some cases, time-based parameter range may go wrong – FIXED
4.   Fixed prompt typos
5.   Other minor bug fixes
Version 1.0.0
Released 11/5/2019
Initial Release
Ampero II Stomp
Version 1.0.2
Released 1/12/2022
Version 1.0.1
Released 11/10/2021
Fixed prompt typos
Version 1.0.0
Released 11/5/2021
Initial Release
mchad
Did it fix your Spring Reverb patches?
