Hot Hand® Wireless MIDI-EXP Controller
Started by Elantric-fgn, June 04, 2010, 09:52:46 AM
Elantric-fgn
http://www.sourceaudio.net/products/hothand/midi_exp.php
http://www.sourceaudio.net/products/hothand/wireless_adapter.php
The Hot Hand MIDI-EXP controller takes all of the expressive potential of the Hot Hand sensor and enables use with third-party effects, hardware, and software by converting the Hot Hand signals directly to MIDI and a flexible expression output. With the MIDI-EXP, users can select from multiple MIDI message types, including continuous controllers, pitch wheel, aftertouch, note on/off message, etc. Other controls fine tune the sensor signals to create the desired response with controls like depth, smoothing, inversion and axis select. A useful Ramp Trigger mode lets the user set a threshold and when that threshold is crossed by the sensor signal, it will generate a ramp in the output.
The Hot Hand MIDI-EXP Controller is available to U.S. customers exclusively through the Source Audio Online Store. If you are a non-U.S. customer and would like to purchase the MIDI-EXP controller, please contact us.
Hot Hand MIDI-EXP Interface
Roll your mouse over the panel controls to learn about each one.
Hot Hand MIDI-EXP Features & Specifications
    * Selectable MIDI message types: Continuous Controller, Pitch Wheel, Channel Aftertouch, Note On/Off.
    * Flexible digital resistor expression output with Tip/Ring switch.
    * Ramp Trigger modes for ramping MIDI messages or expression out when the Hot Hand sensor crosses a set threshold.
    * Adjustable start and stop points as well as speed of the ramp.
    * X and Y axes can be set to send separate MIDI messages simultaneously.
    * Depth, Smoothing, and Invert controls for fine tuning the Hot Hand signals.
    * Save and Recall with 8 preset locations.
    * Familiar foot pedal design with enable/disable footswitch.
    * 9V DC power supply included.
    * Dimensions: 7 in./17.8cm (length not including I/O jacks) x 4 in./10.2cm (width) x 2 in./5cm (height, including knobs).
vanceg-fgn
At this year's NAMM show I heard they would also have a small USB interface which would act as the MIDI receiver for the hothhand and would connect directly to your computer, acting as a direct MIDI over USB interface.  So, HotHand control directly into a DAW ETC.
