Does anybody know of a master 13 pin resources list?
Started by rhcole-fgn, March 15, 2010, 11:32:25 PM
rhcole-fgn
...you know, with the various VGs, the Axon, old stuff like the GR-33, Carvin, Brian Moore...
All of the products presently made and all in the recent past?
If it doesn't exist, we should make it!
MCK-fgn
The following section in the FGN wiki has been created in response to this question :
http://www.futureguitarnow.com/wiki/index.php?title=Roland_13-Pin_Products_%26_Resources
Your contributions towards building this list will be most appreciated. If you're unsure of how to add to wiki please post here and I will move your entry to the wiki. Thanks
Elantric-fgn
SCHOCK SW41 GK-Switcher =
"Change over switch to connect up to 4 GK-instruments to one GK-synthesizer (for example 4 guitars into one VG-99)"
http://www.klausschock.com/Products/products.html
English translation:
Klaus Shock has filled a gap in the market with the SW41, because many musicians have several instruments with GK pickup (such as an electric guitar and an acoustic guitar) and want to GK-device controlling the same.  This stylish and sturdy box turns up to four instruments at a GK-GK device. It will have four different colored LEDs (very bright!) Appears with, which input is active now.  The switch box can also be programmed so that either two, three or four inputs are connected in a circle - who for example, three GK Guitars has so programmed, the Switcher simply as a triple-switch.
The SW41 is available only with Klaus Shock,
RRP: € 199, -
Please send orders and inquiries via email to:
info@klausschock.com
Address:
Klaus Schock
Elly-Heuss-Knapp-Str. 27
72074 Tübingen
Fon: 0049 7071 84038
Fax: 0049 721 151453022
Email: info@klausschock.com
Internet: www.klausschock.com
simont-fgn
Quote from:  Elantric on April 02, 2010, 01:52:00 PM
Cool.
I was looking at this just yesterday. I wonder if the VG99 'freeze' function holds while switching guitars.
Anyone tried one out?
Elantric-fgn
QuoteI was looking at this just yesterday. I wonder if the VG99 'freeze' function holds while switching guitars.
Might be able to "test" this by hitting "Freeze" on VG-99, then unplug your existing  GK13 cable from the VG-99's 13 pin input.
simont-fgn
Quote from:  Elantric on April 02, 2010, 05:05:34 PM
Good thinking. ;)
Just tried it and its works fine. Also stays in 'freeze' when you plug-in again.
