Line 6 JTV 69 Parts Problem
Started by jbsoundideas, September 15, 2021, 08:27:43 PM
jbsoundideas
Just took delivery from a well known major retailer on a brand new in the box JTV-69.
The analog part worked fine but the models did not output any sound.
Battery was new and fully charged.
If I wiggled the output jack around a bit I could get something distorted and low level out of it but nothing usable.
With my electronics background I took out the jack module and there is actually a very complicated set of circuit board there.
The retailer whom I have worked with got 30 years tried to get the replacement part for me.
No part available from Line 6.
For sure I am cancelling the entire o0rder.
Common problem
Gently Lift the Model Knob , to provide enough up /down motion of the Knob when tapped to enable the functional momentary " Model engage Switch" action.
Every new JTV69 Ive played has this problem.
(I took delivery of three JTV-69 before I got one with a straight neck back in 2012 -every one of them  fresh out of the shipping box was inoperable, because the Model Knob on/ off switch can get impacted during transit, pressed too hard. It restricts the "Push/Push" switch action  = non functional.
https://line6.com/support/topic/15208-model-knob-repair-question/
philjynx
Suggest you change your user name to not your email address, unless you like spam;
jbsoundideas
Quote from: philjynx on September 16, 2021, 01:58:33 PM
Could change it to something like "MyCreditCardPinIs4768"  ;D
