Need to make Triple Play wire longer
Started by Verchrona, May 27, 2021, 08:18:13 PM
Verchrona
Hey,
For a specific build, the wire between the triple play pickup and transmitter needs to be about 6 inches longer. I plan to just cut the cable, and splice and solder.
I am however having trouble finding the 8 conductor cable to do so. All I found was 22 awg 8 conductor, which is like guitar cable thick. I need super thin 1/8 inch diameter, stranded 8 conductor. Can someone point me in the right direction to find this cable?
Actually you only need 6 conductor + Drain wire and shield
Small diameter types are here:
https://noramco.ca/product/multi-conductor-stranded-foil-shield-105c/
Verchrona
Ah thanks for link, spent nearly 3 hrs scouring web.
Would you happen to know which if these 8 pins colors I need?
I found this picture on this forum of the inside of the triple play. I assume one some are not in use.
https://www.snapagogo.com/images/2017/06/24/1455753942_1619735701_ExternalFTP_PU.png
Quote from: Verchrona on May 27, 2021, 09:15:57 PM
FTP PU is identical to GK-3 PU wiring -some production builds swap colors , but it's basically
1-sheild  heatshrink
2-ground drain Black
3-string 6 Brown
4-string 5 Blue
5-string 4 Green
6-string 3 Red
7-string-2 White
8-string-1 Yellow
The GK-3 PU
https://www.vguitarforums.com/smf/index.php?topic=3365.0
Verchrona
gearhound22
#5
There used to be premade JST jumpers you could buy on ebay
similar to this (wrong one though)
https://leeselectronic.com/en/product/28585-jumper-wire-jst-5pin-1mm-m-f-set.html
Quote from: gearhound22 on May 31, 2021, 08:27:27 AM
IMHO  those would be inappropriate as there is no foil shield
I have built many such "pickup cables" for various customers over the years...if it all falls in a hole, PM me and we can discuss what you need...
Have a quite a few bits-and-pieces lying around that may do the job..problem is I am in Australia and postage is the pits....at least at the moment.
Cheers,
Peter
