GR-30 now Guitar out sound - Synth MIX L-R works fine
Started by dissoww, May 18, 2021, 11:14:35 AM
dissoww
Just got me a Roland GR-30 + GK-2A + 13pin Cable
Now Guitar sound on "Guitar Output".
GK-2A setting: Synth / Mix /Guitar no result.
Do I need to change some settings to get the Synth and Guitar sound working at the same time?
Opened the GR-30 and Check the soldering points on the output jack socked. And it looks OK. No cracks.
The GK-2a send all data to the GR-30 and sound good.
The Tuning features works fine.
Midi works fine even connected to a Windows 7 (32bit) laptop and used the old GR-30 Editor from 1997 (GR30EDIT.EXE).
I assume you mean "No Guitar sound on GR-30 Guitar Output
Did you connect the short 1/4" cable from normal guitar output on guitar into the Guitar Input on GK-3?
Did you check your GK13 cable?
Is volume on Guitar turn up?
