About amps (sans cabs) in hx stomp and stereo
Started by eddiebellie, March 01, 2021, 08:32:47 AM
eddiebellie
Hi all.
Kind of simple question but I can't seem to find answer.
If I use this signal chain:
Stereo effect1 -> amp (no cab) block -> stereo effect 2 -> cab block
With the stereo of effect1 and 2 be preserved in the output?
Thanx
HX Stomp Amp Block is Mono- will not pass Stereo signals
BROCKSTAR
If you add a stereo gain block as the last block in the path then it should summon the entire path to stereo... don't quote me on this but pretty sure that will work as you're introducing stereo back into the path after collapsing them into mono with the amp / cab etc..
eddiebellie
Quote from: BROCKSTAR on March 01, 2021, 05:27:42 PM
Thanx for the help BROCKSTAR and ADMIN.
