NUX MG-30 Videos
Started by admin, February 13, 2021, 03:18:38 PM
hsuru4u
Quote from: oyobass on July 22, 2021, 02:31:04 PM
It does trails if you switch off the reverb or delay block within a patch, but it doesn't retain tails when switching patches.
They have a "scenes" (allows you to use one footswitch to turn on or off multiple effects blocks within the same patch) feature so you can have up to 3 scenes within a patch that can be switched through with a single footswitch. Using the scenes will also let you retain the trails.
thank you..so do you like the mg-30?
Its a fine unit. Best $300 MFX avaliable  in 2021
oyobass
Quote from: hsuru4u on July 28, 2021, 08:46:07 AM
The sounds are right up there with the big boys. NUX regularly updates the firmware, often incorporating customer requests.
Great unit, great company. Downside is finding them in stock, since the chip shortage limits their access to parts needed to build the things.
Highly recommended!
Ipad MIDI Designer2 app, CME MIDI UHost = wireless control of NUX MG-30
jaropda
Quote from: admin on April 25, 2022, 03:31:40 PM
Hello,you have archive mg-30 midi Designer for mi iPad and I test?
Thank you
Fremen
