CC Mode oddity
Started by fokof, January 25, 2021, 06:23:09 AM
fokof
If for some reason , you want to sent the same CC # from Ctl3/4 , 5/6 , 7/8 than pedal 1 > 10 in CC mode , you have to set the CC number first to the external "ctl" , then to the pedal.
I wanted to set the main Start/Stop of my CPU to ctl 7/8 (CC#41/42)  on all modes on my FC300 but couldn't do it on the CCmode patch #2 , saw later that on that particular patch , I had already set the pedals CC#41 to CC #50 so these number weren't available for ctl 3/4/5/6/7/8.
So , if you want to send the same CC than "pedals" you do :
>Put pedal to OFF , then set the "ctl"  to CC#41 then Pedal 1 to CC#41
Strangely enough , it allows you to do it that way but not the way around
fokof
And another weird thing happening : for the"clt3/4" , the utility mode is reversed , meaning that I got some FS7 , I had to put it to "EXP PEDAL" instead of "CTL" , but only the 3/4 , the 5/6 and 7/8 are OK.
I don't know if it's only on mine.....
fokof
I got another FC300 my my VB99 #2 ( the band practice rehersal unit ) and the unit is OK.
So, the reverse ctl3/4 is only on my "older" unit ....
Strange ???
