LEFT VOLUME AND RIGHT VOLUME? EQ LEFT OUTPUT / EQ RIGHT OUTPUT
Started by Jdanthony842, January 24, 2021, 02:27:55 PM
Jdanthony842
HELLO IM HAVING A BAD DAY WITH THIS..... I UNDERSTAND THE PANNING TO LEFT OR RIGHT WHEN USING LEFT MONO 1/4 AND RIGHT MONO 1/4 TO 2 TUBE AMPS ....FX RETURN ONLY.
MY PROBLEM IS WITH THE OUTPUT THERE IS NO ABILITY TO INDIVIUALLY TURN DOWN THE LEFT OR RIGHT MONO SIGNAL OR EQ THE LEFT OR RIGHT INDIVIUALLY ......
NOW WHEN I CHANGE THE PATH TO STEREO I SEE THE MIX AND I CLICK ON IT....... BUT SINCE YOU CANT PUT ALL THE FX BLOCKS IN THE TOP OR JUST THE BOTTOM SPLIT PATH YOU DONT GET TO USE 3 BLOCKS IF YOU DONT WANT THEM SPLIT ( THAT IS THE ONLY WAY I CAN MAKE THE LEFT OR RIGHT LOWER OR LOUDER IN VOLUME IS PAN IN A STEREO PATH ?
SOMEONE PLEASE HELP...THANK YOU
