Variax 300 and Firehawk FX
Started by Carlos Velho, November 22, 2020, 04:28:17 AM
Carlos Velho
Hi to all. I bought a used variax 300 and some things are very new to me. I use a firehawk fx to connect the variax and run the app on android but I don't have the tunings available. They are not high lighted to make the choices. All other things are fine, AFAIK. When I call, for ex, a patch DADGAD Kashmir or Open A Brn Sugar, I can see the alt tunings but not the altered sound. It still standard. Is this a limitation on firehawk or something goes wrong? I use the original cable to connect. The alt tunings chosen directly from Variax are fine. Don't know if I can install the monkey to make it better. The dealer here are not so great and I cant even find the interface to connect on PC. Thanks for any help.
Carlos Velho
All I have found about the question with the 300 and firehawk is I can't do what I want on tunings. The only way to do that is with the VDI interface workbench. And I can't find it on my country just found in America or Europe but they don't deliver to Brasil. 3rd world is a pain in the ... ::)
Quote from: Carlos Velho on November 25, 2020, 06:14:42 AM
You can NOT use Workbech HD on Variax 300
Line-6 made a break away from the 1st generation Variax Electric ( Models 300/500/600/700) vs the post 2010 era "VARIAX HD" models (All Tyler Variax, SHURiKEN, Variax Standard)
And it depends on what firmware is loaded in the unit
The "key" - review the specific hardware that supports original VARIAX WORKBENCH app  - required for your Variax 300
Any of these will work
POD HD Pro
POD HD500
POD X3 Live
POD X3 Pro
PODxt Live
Variax USB Interface
Vetta II Combo
Vetta II Head
Line-6 hardware with VDI Interface not on the list above will NOT work with your Variax 300
Carlos Velho
Ok. Thanks for the answer. I just can call the models inside the guitar from Firehawk. greetings
