GT1000; IR db setting?
Started by macman70, October 12, 2020, 02:01:46 PM
macman70
When using a IR in the GT1000, is there a way to adjust the dB setting? Similar to what you can do on the Helix or Headrush units.
I have the GT1000 and it is not too obvious if you can adjust it.
elbazuk
Hi there,
In short no - not directly.
You can add an EQ before, OR after the SPeaker block now as of the latest updates, so you can adjust the level going into or out from the IR to the final exit destination in your patch.
For example, when using OwnHammer IR's, in their PDF they tell you to apply a -3db cut to 400hz with a Q of around 0.5 - 1 to simulate a tube power amp more accurately, which is now possible.
What does the dB setting in the other modellers do exactly? Affect the incoming signal?
