Casio High Tech Guitars ( MG-510, PG-380, DG-20, EG-5)
Started by Virtual Tone, February 12, 2008, 06:21:58 PM
spmcmw
#52
https://www.vguitarforums.com/smf/index.php?topic=29186.msg250583#msg250583
Casio EG-5 cassette tape looping with the built in cassette player
JefffM
Does anyone know of a source for spare parts for the Casio DG-20 or maybe have a non-working one?  I'm after a string sensor cover.
Thanks.
Casio MG-510  - played by Del Casher
@ 2:55 he enables the MIDI Output, and the MG-510 faithfully tracks all he plays
https://www.vguitarforums.com/smf/index.php?topic=20073.0#msg144725
kotroj
Hi, everybody,yesterday I bought  Casio MG-510, I use it with soft instruments in DAW, it's all right,  but two things stand in the way: during playig sustain it decays quite quickly-e.g sound doesn't last as long as I need. The question: can I setup it inside the guitar?  And one more thing. During playing glissando the sound often disappears. But when I play the same soft instrument via fx Jam Origin  MIDI Guitar 2, there are NORMAL sustain and glissando. Is there possibility to set up sustain and glissando inside Casio MG-510? Or is there another solution? Thank in advance.
#59
Yes you can change midi settings and poly/mono mode
See attached
peterpeng2015
Electric guitar with midi function, very convenient to make TAB score
Quote from: peterpeng2015 on October 25, 2022, 03:15:58 AMElectric guitar with midi function, very convenient to make TAB score
True
Many products we talk about here perform the Guitar to MIDI function
Roland GM-70
Roland GR-50
Roland GR-1
Roland GR-09
Roland GR-30
Roland GR-33
Roland GR-20 (Guitar or Bass)
Roland GR-55 (Guitar or Bass)
Roland VG-99
Roland VB-99 (Bass)
Boss GP-10
Boss SY-1000 (Guitar or Bass)
Fishman Tripleplay
Axon Ax-100
Axon Ax-50
All above can output MIDI NOTE data on 6 separate MIDI Channels - (one per string)
Gear below can output single note MIDI NOTE data on one MIDI channel only
BOSS GT-100
BOSS GT-001
