Axon AX100 Mark 2 String Split help
Started by bombayroom, March 13, 2020, 05:44:52 AM
bombayroom
Even with the manual, I am not able to do a string split. What I am trying to achieve is having only the bottom 2 strings (the low E and the A string) play the Upright Bass, while the top 4 strings are only my regular, guitar magnetic pickup.
Any help out there?
Quote from: bombayroom on March 13, 2020, 05:44:52 AM
Any help out there?
Your regular Mag pickups will Always output the low E & A strings
Do you have the Internal Waveblaster Synth Board installed on Axon AX100 MKII ?
If driving external synth - it must be a specific model which supports MIDI MONO MODE
Multitimbral Tone Modules 5-Pin MIDI
https://www.vguitarforums.com/smf/index.php?board=50.0
bombayroom
I don't know if I have the internal waveblaster synth board.
I'm not using any external devices.
It would be acceptable to always sound the low E and A strings with the magnetic pickups. Im just trying to get the upright bass to be applied to only the loe E and A strings.
Thanks!
QuoteI don't know if I have the internal waveblaster synth board.
Do you hear Synth tones from Axon Audio Output?
If Yes- then you do have the internal Synth board
Spend more time with Axon Win / Mac Editor
https://www.vguitarforums.com/smf/index.php?topic=25907.0
Dalai_llama
Any help out there?
1. Create the split;
2. Assign the Upright Bass to your Low e and A strings;
3. Assign whatever sound to other strings with output volume 0.
I had a patch on my Axon exactly like that, only the bass was fretless.
gearhound22
bombayroom did you get it sorted?
I could maybe send you a patch where string splits works (as long as your soundcard is in there!)
