Accidental Surprise: SE+ Multi-FX For Freeze, FX and REVERB
Started by Rhcole, February 18, 2020, 11:30:11 AM
Rhcole
I was working with the SY-1000, and as I have bellyached in other posts, wanting more FX from this new beast. I wanted additional reverb, some way to add Tri-chorus without using all of the resources, other miscellaneous FX.
Also as I have mentioned elsewhere, I don't want a choo-choo train of add-on boxes to the FX I/O.
Experimenting with the SuperEgo+, I hit upon a combo that has never occured to me... genius that I am.  ::)
I had the Decay set a little past Noon, and the Layer also set  somewhere around 1 O'clock, and the SE+ produced a decent reverb added to the sound. Needed tweaking and more like an "oil can" reverb than a plate, but certainly usable.
This removed one of my dedicated FX blocks from the SY right there!
Then, I used the SE+ chorus feeding into the SY-1000 Dual chorus (1 FX block), and boom, I had a beautiful, lush Tri-chorus with reverb!
So now, I can use the SE+ as a true Multi-FX pedal: Reverb, any of the 11 FX, plus freeze all at once.
Damn fine pedal.
