Source Audio - One Series FX MIDI USB Compliant w/ Neuro for remote Control
Started by admin, January 13, 2020, 12:53:38 PM
https://www.sourceaudio.net/editorsandfirmware.html
The Source Audio ONE Series FX range are interesting and they are all Stereo I/O, but also pass a bi-directional data transmission between each pedal using the TRS RING connector  and have a fast well behaved  / lag free SmartPhone "Neuro Mobile Editor app for Android / IOS devices and MIDI USB Class Complaint Mini USB port
Use the Neuro Cable to connect your Neuro Mobile App to any Source Audio One Series pedal. One Series pedals include the Ventris Dual Reverb, Nemesis Delay, Vertigo Tremolo, Aftershock Bass Distortion, L.A. Lady Overdrive, Gemini Chorus, Lunar Phaser, and more. The Neuro Cable is 3 ft. long and connects from the headphone jack on your mobile device to the Input 2 on your One Series pedal.
In this manner the Neuro Mobile Editor for smartphones using a TRS Headset connection to the 1st ONE Series FX's Control TRRS  input may control and download new patches to each SA One Series FX in the daisy chain
The ring contact on Output 2 acts as a data connection for the Neuro App, passing data from the Vertigo to the next Source Audio effect in your signal chain. You can daisy-chain the Neuro App data regardless of whether Output 2 is configured to output audio or not. Connect Output 2 to the next device's Neuro App Data input (usually Input 2) using a stereo (TRS) ¼" cable. The audio signal (if applicable) will be on the tip contact of the plug, and the Neuro App data will be on the ring contact.
