SY-300 - FX Loop
Started by loopman, October 23, 2019, 08:49:44 AM
loopman
Ok, after trying the Meris Enzo into the THRU/Return jacks of my SY-300, I understood that the best solution is to have them working independently, so they have to work in Parallel
For example imagine the arpeggiator of the Enzo running in backgorund while at the same time I can play different sounds/patches on the SY-300 and viceversa too.
Ok, now my choices are two :
1) EHX Tri Parallel Mixer
2) Boss LS-2 Line selector
with the EHX pedal I'd have a problem, that is it has only One main output, thus when I connect the two Outs of the SY-300 ( for the stereo effects) into the Return 1 and Return 2 of the Tri P Mixer I will loose the stereo image coming from the SY-300,right? It wouldn't be a problem for the Enzo that I'd use in Mono
can the Boss LS-2 help me to keep the stereo image of the SY-300 + the Enzo in mono?
Any ideas/suggestions are welcome
Boss LS-20 is Mono only - it does allow you to select one of two separate Mono Loops
If all effects are in parallel  feeding a mixer, this opens up your options
This one below is True Stereo
https://empresseffects.com/products/buffer-stereo
loopman
I hadn't heard of the Empress effects solution before...It's nice, but the problem is still that if I use the Loop in 1 & 2 to feed the two SY-300 outputs, then how can I feed the Meris Enzo's Output? I'd need of the another Loop in 3 on the Empress mixer, right? or, I could use the other Input on the Empress Mixer named " Input 2 " for the Enzo out
If only the EHX Tri Parallel mixer Main Output was stereo with a TRS plug cable, I'd use an Y cable to feed the Eventide H9 placed after the Tri Parallel Mixer in my chain
any other suggestions?
Quote from: loopman on October 23, 2019, 10:15:50 AM
DIY
ElliotG
Do you need a mixer for performance (stomp box style) or for a studio?
The Enzo is also very nice in stereo.  I'd suggest looking or at least a 4 ch mixer.
You would mix the 4 outputs down to a stereo pair.
Saturn works has a number of stompbox style mixers:
https://saturnworkspedals.com/product/summer-mixer-pedal/
There are lots of small passive mixer for studio use, just one example:
loopman
Quote from: admin on October 23, 2019, 10:21:08 AM
DIY
do you mean the Y cable? Ok, I already have one : TRS to dual mono TS , but It wouldn't work if the main Out of the EHX Tri Parallel mixer is mono...
Quote from: ElliotG on October 23, 2019, 10:24:05 AM
I need a little mixer for performance, stomp box style
Saturn seems to be good, I will check it
Quotedo you mean the Y cable?
Roll your own switcher with a soldering iron
loopman
Ok, can you explain me better? If possible, give me an example of what do you mean, because it's important for me to understand how to find a solution to my setup scenario
Thank you so much
There's also this mixer/split
https://www.soundonsound.com/reviews/art-splitmix4
Works great but only in mono OR stereo.
(And can be used as both a mixer and a split at the same time.)
It's cheap, small , lightweight.
You can't turn on off by stomping but Sy can be turn off either by stomping or expression pedal and I imagine that Enzo can to.
Quote from: loopman on October 24, 2019, 02:12:39 AM
Thank you so much
Most options are listed here - review their individual specs for what you need
https://www.thomann.de/ie/switch_pedals.html
loopman
