GR-55 Floorboard Editor Crash during Bulk Write
Started by JeffTronics, July 15, 2019, 06:49:45 PM
JeffTronics
What would case the floorboard editor to crash after it completes a Bulk Write process? It finishes, shows completed, and quits.
It crashes regardless how many patches I write to.
occurs both in High and Low resolution
When reopening the editor, the write changes were completed.
Do you need me to paste the crash log?
Mac 10.12.06 (recently installed clean)
GR-55 FloorBoard - version 20140820
JT
Quote from: JeffTronics on July 15, 2019, 06:49:45 PM
You seem to be using a very old version from 2014, the mac version has been updated about 6 times since then,
this is the current version
https://sourceforge.net/projects/grfloorboard/files/GR-55/GR-55FloorBoard_mac_installer.pkg/download
try that and let me know if it works better (and hopefully not worse  :D )
JeffTronics
Thanks for pointing that out. What's odd is, before i posted i grabbed the installer pkg, and installed it. i would have thought it would overwrite the current app version in my apps folder. I will perform a clean install this time. Thanks for the reality check. I'll check back on the outcome  later..
Thanks for the support :)
JeffTronics
Here's what I downloaded and installed. I removed the previous version to the trash. Are there any other helper files like prefs I should trash too? I'm asking because I'm having the same problem with the downloaded version: GR-55 FloorBoard - version 20180808
© Copyright 2019
For what it's worth.. I am batch writing a change to the JC-120 AMP, which I have across 9 patches. Seems to be any type of change but as an example if I toggle the Amp's solo SW on/off. I have not tested/tried other types of changes but guess I could.
Quote from: JeffTronics on July 15, 2019, 09:05:50 PM
© Copyright 2019
What version of macOS?
I will look into it and try to replicate the problem (after I backup my own GR-55 first).
JeffTronics
