Adjusting distortion with the Exp Pedal.
Started by IGMartin, May 31, 2019, 07:26:16 AM
IGMartin
I'm trying to adjust distortion / overdrive of organ patches  with the Exp Pedal but when you go to "heel" position the volume is minimal. Checking on the manual it says:
"DRIVE" parameter (0-127) adjusts the amount of distortion. The volume will change together with the amount of distortion"
This kind of negates the adjustment of only the distortion / overdrive !
Has anybody found a way around this?
thanks
Iggy
