Pass through capabilities of MIDX-20??
Started by MountainCraft, April 24, 2019, 07:15:40 AM
MountainCraft
I want to use my MS-3 to control my GP-10 (mainly PC messages) and my Whammy DT (also PC messages), but it would be cool if I could use an expression pedal to control the volume faders on my XR-18 mixer for the stereo outputs of both the MS-3 and GP-10..
Can the MIDX-20 pass CC messages from the MS-3 to the XR-18 via the regular DIN MIDI port?
I'd have to make a MIDI splitter to send to both the XR-18 and Whammy DT (but not sure if the splitter would go before or after the MIDX-20)
The idea would be to have the expression pedal control a DCA (or IDCA) on the XR-18 in the same way a control surface is used...
I'd also want to send PC messages to the XR-18 to turn channels on and off, but I'm thinking if it can pass through CC messages from the MS-3 there, it can also pass PC messages too..
Essentially, I'm hoping to use the MS-3 as the MIDI host for the GP-10, the Whammy DT, and the XR-18 (and whatever other standard MIDI device I want to add in the future)..  Can the MIDX-20 allow all of this to happen? Pretty sure I could do it without the GP-10 or MIDX-20, but I need to add the MIDX-20 to allow the GP-10 to be controlled by the MS-3 too..
CodeSmart
Hi MountainCraft,
If I understood you correctly this is what you want to do:
PASS THROUGH/REPEATER
The arbitrary MIDI commands (PC and/or CC or multiple) sent from the MS-3 (programmed by BTS) will be transferred via MS-3 USB connector to the MIDX-20 (preferably the upper USB connector). The MIDX-20 will repeat and output these commands to the other USB connector (lower) to the GP-10 and to the 5-pin MIDI OUT connector.
MIDI SPLITTER (a.k.a MIDI Thru Box)
The 5-pin MIDI OUT is connected to a MIDI splitter (preferably active). The splitter is connected to the Whammy and the XR-18.
Note: You don't need a MIDI splitter unless you want the EV-5 to control both the Whammy and the XR-18.
Just connect the 5-pin MIDI of the MS-3 directly to the device not to be controlled by EV-5. The MS-3 actually sends MIDI both to 5-pin MIDI as well as the USB connector hi-jacked by the MIDX-20.
EV-5 PEDAL
The Roland EV-5 can be enabled to output any MIDI command (or multiple commands or channels) controlling any of the MS-3, GP-10, XR-18 devices (programmed by MIDX-20 PC Assistant program).
MIDX-20 FIRMWARE VERSION
Regardless of firmware version you flash into the MIDX-20 anything sent by the MS-3 will be repeated to the other ports, and regardless of firmware version the GP-10 will recognize PC commands and CC commands by ASSIGNS.
GP-10 Bridge is only needed when the GP-10 ASSIGNS is not enough, i.e. deep control.
MS-3 Bridge is only needed if you want to deep control the MS-3.
A risk identified is that when GP-10 sends PC-changes it might change the patch number of the MS-3 if they are using the same channel. This can be avoided by setting up the MIDX-20 properly (MIDI blocking or translation, something the MIDX-20 does very well).
I hope the above answers your question.
/Robert
MountainCraft
Quote from: CodeSmart on April 24, 2019, 03:36:33 PM
Hi MountainCraft,
EV-5 PEDAL
/Robert
In my mind, I was connecting things like this..
MS-3 5pin DIN out > MIDI splitter
>1st output of splitter to Whammy
>2nd output of splitter to MIDX-20 5 pin DIN in> MIDX-20 USB> GP-10 USB in
>3rd output of splitter to XR-18
Expression pedal (EV-30) with one side connected to MS-3 and the other to MIDX-20 (or GP-10?).. Sometimes (depending on how the patch is setup) the pedal controls an effect (or volume) in the MS-3, other times volume for both MS-3 and GP-10, yet other times volume control for 2 (or three) linked pairs of faders on the XR-18 (or a DCA to do the same.. not sure if there's a way to access IDCA's in Mixing Station Pro to do that, but if so, that's the ideal route)..
An additional dedicated Expression pedal (probably EV-5) is a possibility for controlling the XR-18  DCA/IDCA fader..  and in that case, then the EV-30 would simply be plugged into both the GP-10 and the MS-3 and used for either depending on what a particular patch calls for...
I'm not really sure what the MIDX-20 does or is capable of.. I don't know what 'bridge refers to.. All I know is that it's the only way that the MS-3 can send PC messages to the GP-10..  I want to set up single button control for the whole pedal board, and from what I'm told, the MIDX-20 is the only way to get the MS-3 to control the GP-10...
If it is able (or required) to be connected together via the USB, then that opens up the MS-3's 5 pin DIN connection (as well as the MIDX-20's) for the Whammy and XR-18, no?  Until now, I hadn't even been thinking that way..
Would love to be able to do all this while the computer is connected to both the GP-10 and the MS-3 (editors/librarians/BTS), but that's probably wishful thinking.. Ideally, everything would be connected to the mixer/laptop via one USB and/or one MIDI cable and I could run the MS-3 to control everything and also run the editors on the laptop...  But I would think that that requires a USB hub, and from what I understand the MIDX-20 won't play nice that way..  (hate unplugging things and repatching to do that sort of stuff)...
So I'm not really sure how it all connects.. I only know what I want it to do (and even that is a little fluid).. Trying to eliminate what's not possible, so I know what is...
QuoteI'm not really sure what the MIDX-20 does or is capable of.. I don't know what 'bridge refers to.
All MIDX-20 features are explained in sequence of development here (29 pages)
https://www.vguitarforums.com/smf/index.php?topic=17561.0
CodeSmart
Your approach would work too. There's many ways to skin a cat.
To understand the MIDX-20 you need to read both of these manuals.
http://www.primovasound.com/pdf/MIDX20_Manual.pdf
http://www.primovasound.com/pdf/MIDX20_Assistant.pdf
'Bridges' are optional Boss Device specific firmware extensions.
GT-1 Bridge - Required to control a GT-1 using MIDI.
MS-3 Bridge - Required to control a MS-3 using MIDI.
Katana Bridge - Not required for Katana native MIDI, but if available everything in Katana may be controlled (sneaky amps etc.)
GP-10 Bridge - Not required for GP-10 native MIDI, but if available more things of the GP-10 may be controlled.
Regarding the 5-pin MIDI in/out they can be setup for MIDI thru.
MountainCraft
Quote from: CodeSmart on April 25, 2019, 03:53:55 PM
Thanks guys.. Slowly reading through everything now..
Once ordered, how long does it take to get the device (Northern California)?
Hoping to have the moola within 1-5 weeks (more towards 1-2 weeks, I hope)..
Is 5 meters the longest cable available? (someone needs to make a coupler  ;D )
if ordered at the same time as the MIDX-20, is shipping free on the cable, and if not how much extra is the shipping on the cable?
Thanks,
Mark
CodeSmart
Quote from: MountainCraft on April 26, 2019, 06:05:14 AM
Thanks,
Mark
Shipping should be the same if total weight is less than 1kg.
Longest I have is 10 meter S-A.
Also have : 5 meter S-S,S-A,A-A, 3 meter S-S,S-A,A-A, 1 meter S-S, A-A, 0.5 meter S-S, A-A
Please contact me at sound@primova.se
(I don't check e-mails everyday because I also have a day job and a trying to have a normal life)
MountainCraft
Quote from: CodeSmart on April 26, 2019, 10:54:14 AM
Alright, cool!
(I hear ya about eMail. lol)
