AMPERO - FAQ
Started by admin, February 23, 2019, 01:54:17 PM
At this hour in North America - all Amperos from the 1st batch are sold out , and despite the issues I have reported (and solved), I never see any "used" Amperos for sale
Next Batch is due later this month.   - But I figure add a few weeks
https://reverb.com/item/19622527-hotone-ampero-amp-modeler-and-effects-processor-pedalboard-preorder-ships-in-early-may
https://www.hotoneaudio.com/distributors/
(in USA - Samson(Sam Ash)  is the Distributor)
https://trademarks.justia.com/owners/sam-ash-music-corporation-2462282/
(in Canada - Korg  is the Distributor)
"on paper" the Mooer GE 200 appears comparable, but playing both side by side, the Ampero had a very satisfying tone/touch response and feel  - while the Mooer tones seemed more like playing Jamup Pro on an iPad  =OK but the Ampero sounds superior to my ears.
The 1st batch with internal ground loop noise is a relatively easy fix
AMPERO - Top Things to Know
https://www.vguitarforums.com/smf/index.php?board=294.0
carlb
Quote from: admin on March 03, 2019, 08:08:51 PM
Ampero on battery power (19VDC)
PilotPro 32,000 mAH Battery pack
Any notion of the range for current draw? Guessing somewhere north of 100mA, but probably closer to that 500mA at startup.
Trying to figure out an all-in-one small(ish) power supply for a gig rig ...
Morningstar MC8 & MC6
QSC CP8 powered speaker
Its 500 mA with higher short duration inrush current demand at startup
It ships with 18VDC @ 1500mA supply
But can run on battery power with the right supply
carlb
Thanks, Steve. That's a power-hungry board! Must be the color display and non-custom DSP chip.
That 18Vdc at 500mA is more than most compact power supplies are rated for. I'll keep looking.
Need:
18Vdc @ 500mA for the "RUNS-HOT-ONE"
9Vdc @ 350mA for the GP-10
9Vdc @ 250mA for the MIDX-20
9Vdc @ 100mA for the MC6 (via the MIDX-20 USB)
Could go with two power supplies for the above, but would like to keep one of the three 120Vac outlets on the rig's power cable as a "courtesy outlet." Many a gig where someone can't get to an outlet and so plugs into the back of my rig.
Quote from: carlb on April 07, 2019, 02:37:57 PM
Need:
You will need at least  2 battery packs
Rolloq
Does mac os 10.6.8 work with Ampero editor?
Regards Rolloq
Quote from: Rolloq on April 26, 2019, 09:13:28 AM
Regards Rolloq
I believe that is too old
contact  Hotone
Rolloq
https://www.facebook.com/groups/HotoneAmperoUsers/
Data Leak wrote>
Have tested the (Choptones Patches for Ampero)  and after studying the settings it taught me:
1: Always use the PEQ because only then you have Low Cut and High cut parameters.
2: Secondly for High Gain sounds the use of IRs are obligatory! So a good IR combined with the PEQ is very effective.
3: Thirdly If you need more low mids turn open the Master of your Amp block.
Many thanks to Livio, the man behind Choptones!
QuoteRecommend a MIDI Foot controller for Ampero?
Be sure to locate a MIDI controller that can assign each foot switch to actually "toggle" MIDI CC# with each switch tap. Avoid the Cybery - because it can not "toggle" MIDI CC# with each switch tap. Most low cost MIDI controllers will require one footswitch for Ampero FX "ON", and yet another footswitch for Ampero FX "OFF", - will require FOUR separate footswitches just to control only Two Ampero FX on / off ( lame)
The Morningstar MC6 MKII provides much higher level of control and functional User Assignments options than anything else in that price range and much easier to program with its HTML5 based Editor ( compared to Damage Control)
https://www.morningstarfx.com/mc6-mkii
Read the new 45 page Ampero owners V30 Manual
If you are on a Windows PC, Download and install the Ampero Editor V1.2 - then look here: for the 45 page Ampero _Manual_EN.pdf
C:\Program Files\Hotone\Ampero Editor\Resource\Ampero\File
Ampero Editor Release Note
Version 1.2.0
Released 5/31/2019
Precaution
IMPORTANT - Use V3.0 firmware with Ampero Editor V1.2.0 ONLY. The new software will no longer recognize Ampero units with previous firmware (V2.1 and earlier).
The patches of the earlier firmware versions are now not compatible with this V3.0 firmware due to the new features and fatal changes, which means, after updating firmware, ALL YOUR PATCHES IN YOUR AMPERO WILL BE REPLACED BY THE NEW FACTORY/USER PATCHES, AND YOUR CUSTOM IR FILES WILL ALSO BE CLEARED.
Please be sure to export the patches you want to keep by using earlier Ampero Editor software before updating. After updating, you can import them via new Ampero Editor (The Editor will automatically convert your old patch files to new version so that you can use them with V3.0 firmware).
If you accidentally updated to the new firmware before backing up your patches, to get the old patches back, you can roll back to earlier firmware versions (load earlier firmware files when updating) before you edit/save patches with new firmware.
New Features
+ You can now manage your signal chain by clicking "Manage Signal Chain" button
+ You can now import user IR file with any bit depth/sample rate
+ You can now set No Cab Mode in Settings > Global
+ You can now check solution methods by clicking "Device Not Found" button when Ampero Editor cannot recognize your device
+ EXP 2/FS settings added in Settings > Global
Improvements & Bug Fixes
+ Some effects in Effect List have no image – FIXED
+ Some effects in Effect List have wrong images – FIXED
+ Optimized USB communication stability between computer and Ampero unit
Version 1.1.1
Released 3/14/2019
Precaution
In this software update, we changed USB communication methods between Ampero and your PC/Mac, which means, the new software will no longer recognize Ampero units with previous firmware (B6.4 and earlier). PLEASE UPDATE YOUR AMPERO TO THE LATEST FIRMWARE FIRST before using the new software.
Bug Fixes
- Ampero Editor crashes when importing presets containing user IR files – FIXED
Version 1.1.0
Released 3/12/2019
Precaution
In this software update, we changed USB communication methods between Ampero and your PC/Mac, which means, the new software will no longer recognize Ampero units with old firmware. PLEASE UPDATE YOUR AMPERO TO THE LATEST FIRMWARE FIRST before using the new software.
Bug Fixes
- In some cases, presets cannot be correctly imported/exported – FIXED
- Quick Access Knobs, EXP 1 & EXP 2 settings cannot be correctly read in CTRL menu – FIXED
Version 1.0.2
Released 2/14/2019
+ Quick start tips added at the first launch
- Effect description mistakes – FIXED
- Ampero Editor cannot get correct information from Ampero unit after factory resetting - FIXED
- Sync selections display error – FIXED
- Language selections aren't working properly (Windows) – FIXED
Version 1.0.0
Released 1/25/2019
Initial Release
0:52 Review of the first presets
6:44 Emulations of amps
10:48 Emulations of OD / Dist
14:44 Emulations of modulation
18:44 Effects of Wah
19:07 Effects of Whammy
19 : 34 Effects of Delay
24:07 Effects of Reverb
27:44 Simulations of screen
33:58 Effects to the input of an amplifier (Blackstar HT5)
42:45 Connections
45:23 Functions of the footswitches
47:21Your questions about Hotone Ampero
48:57 "Gap" in the preset change
51:07 Tour through the clean sounds
1:02:13 Function "Spillover" in delays
1:04:23 Function looper
1:05:38 The best and the worst Join Guitarists: https://www.guitarristas.info
https://www.hotoneaudio.com/news/330.html
Hotone Friday July Edition
Hotone Friday: July Edition!
It's Hotone Friday! Yes, you guess it: MORE AMPERO! :)
1. Ampero firmware and software got updated!
Check the update log here:
Ampero Firmware Version 3.1
New Features
1. Wait Mode is now available when you use MIDI controllers to switch between banks
1. Reduced the default volume of drum machine
2. Further optimized Tuner sensitivity
3. Shortened the fade in time when engaging compressor effects, this may cause a noticeable fade in progress when switching between patches
4. Tuning mode will now be automatically saved
5. Tuner cannot be engaged by sending CC 57 – FIXED
6. CTRL function may not work correctly when sending CC 72 – FIXED
7. Irregular output level may occur after importing some user presets – FIXED
8. Irregular on/off status display when using external footswitch to control drum play/stop – FIXED
9. The expression pedal range min/max values can still be set when unassigned – FIXED
Download them here:
Ampero Firmware English V3.1
http://www.hotoneaudio.com/downloads/software/Ampero/Ampero%20Firmware%20English%20V3.1.zip
Ampero Editor Version 1.2.2
New Features
Firmware V3.1 support added
Download them here:
Ampero Editor Setup 1.2.2 for Windows
Ampero Editor Setup 1.2.2 for Mac
https://www.hotoneaudio.com/downloads/software/Ampero/Ampero%20Editor%201.2.2%20for%20Mac.zip
https://reverb.com/item/26328215-hotone-agb-1-original-gig-bag-for-ampero-multi-effects-pedal
Hotone Ampero Live gig patch suggestions
Mike Duncan wrote>
It just requires pressing 2 buttons but you could hard patch the bank ready to go if you need to go from a clean directly to a solo. You're effectively getting 6 patches per bank this way.
Bank 1: General all songs
Clean + CTL delay for solo
Crunch + CTL Delay for solo (blues sh**)
Marshall type Drive + CTL Delay and reverb for solo (Parisienne sh**)
Bank 2:
Prince clean and as in bank 1 but Patch 3 hard wired for solo
Bank 3:
Dire straight and ZZ top but Patch 3 hard wired for solo
Patch 1 Drive
Patch 3 Solo hard patched
https://www.facebook.com/groups/HotoneAmperoUsers/488411818603715/?comment_id=490018105109753&notif_id=1567176000151085&notif_t=group_comment_reply
QuoteElantric, I think you may have said something in passing about this. Is there any way to sort of fudge an in/out for an external effect pedal or at least drive an external effect pedal?
Yes  - run an external MFX  in parallel with Ampero
think of the Ampero's 3.5mm TRS AUX INPUT as a Stereo mix bus input, where you feed the stereo outputs from an external effect
You could use a SY-300 -
Guitar > SY-300 GUITAR INPUT >SY-300 THRU OUTput > AMPERO GUITAR INPUT
then route SY-300 3.5mm TRS Headphone out > 3.5mm TRS AUX Input on Ampero
Ampero XLR Out to PA
Could use a GR-55 with Ampero in a similar manner
Create patch where Ampero Expression Pedal control Volume which is 1st in signal Chain
spiral said: ↑
I wanted it to work like a volume pedal in front of an amp which I was able to do by putting the EQ block first in the chain, and then assigning the Exp. 1 pedal to the volume of the EQ. This makes it act like a real volume pedal before your amp and effects so you can get rising gain, and reverb and delay trails that don't get turned down.
Ampero Firmware Version 3.4
Released 11/29/2019
New Features
1. You can now choose the system language and switch different theme colors (Global > Display)
You can now change the parameters on the main display screen by sliding and long pressing
2. In Global menu, you can now set the footswitch to control a single module on/off
3. In Looper menu, you can now customize the footswitches function
4. The new Save menu has been changed, you can use the QWERTY keyboard to change the patch name
5. The new Locked menu has been changed
6. The new Drum menu has been changed, and the BPM sync function has been added
Improvements, Changes & Bug Fixes
1. Connecting software to change Graphic EQ  parameters may cause crashes – FIXED
2. Connecting software to change the effect chain may cause crashes – FIXED
3. Connection software to change some parameters Ampero may not respond – FIXED
4. Minor bug fixes
Click to download Ampero Firmware V3.4
Ampero Editor Version 1.2.6
Released 11/29/2019
New Features
1. Added support for Firmware V3.4
2. Support window resizing by dragging freely
3. Redesigned "connection" page
Bug Fixes
1. Fixed description errors of some of the effects
Note: Ampero Editor V1.2.6 is only compatible with firmware V3.4 or later
chrisizonvg
# Ampero Firmware Version 3.5
Released on 12/25/2019
1. Drum tempo will sync to patch tempo when you turn on drum sync switch in Looper menu – FIXED
2. Volume knob and main knob malfunction in Save menu – FIXED
3. Optimized touch screen operation when sliding on lower right corner of parameter bar)
4. Optimized input signal procession for better sound quality when using with basses
5. Other minor bug fixes
# Ampero Editor Version 1.2.7
Bug Fixes
1. Abnormal window size when launching Ampero Editor at the first time – FIXED
2. No UI image on some computers – FIXED
3. Patch file may not be correctly recognized if 3rd party IR contained – FIXED
4. Wrong parameter display when using Para EQ on Ampero Editor – FIXED
5. Device firmware version may not be recognized correctly – FIXED
6. Parameter values in a patch cannot be correctly pasted after copying a patch (right click on a patch name in patch list) – FIXED
DAW  Logic, Reaper, GarageBand -  Lova Nova 4 all https://soundcloud.com/lova_nova
Mine still works like new - but some Ampero users report a streaking LCD display
Solution for Ampero LCD Streaking
(with Ampero FW 3.6 Engineering Test Mode)
Ampero FW3.8
Ampero Firmware Release Note
Version 3.8
Released 4/28/2021
Attention
This Ampero V3.8 firmware update brings you new effects, more powerful features (e.g. 10 more user IR slots), optimized system performance and bug fixes. We recommend all Ampero users to execute this update for the best possible user experience.
IMPORTANT – Use V3.8 firmware with Ampero Editor V1.3.0 ONLY. The patches of earlier firmware versions are now NOT compatible with this V3.8 firmware due to the new features and changes, which means, after updating firmware, in some situations, your unit may not work properly.
Please be sure to export all patches by using earlier Ampero Editor software before updating. After updating, you can import them via new Ampero Editor. The Editor will automatically convert your old patch files to the new version, so that you can use them with V3.8 firmware.
If you accidentally updated to the new firmware before backing up your patches, you can still roll back to earlier firmware versions (load earlier firmware files when updating) before you edit/save patches with new firmware.
New Features
New system language added (Global > Display)
10 more user IR slots added in CAB module
Low cut/high cut parameters added in CAB module
Blend parameter (wet/dry signal ratio) added for Squeezer - Hotone original compressor effect available in FX1, FX2 modules
Precise Attack – CDCM HD overdrive/boost model available in FX1/FX2 modules, based on Horizon Devices® Precision Drive*
Forest Boost – CDCM HD boost model available in FX1/FX2 modules, based on Fortin® Grind*
Sweller – Hotone original slow attack model available in FX1/FX2/FX3 modules
*The mentioned manufacturers and product names are trademarks or registered trademarks of the respective owners. The trademarks were used merely to identify the sound character of this product.
Optimized built-in expression pedal indicator in Main Display menu with a clearer on/off status display
Optimized built-in expression pedal performance for better user experience when using as a Wah pedal
Full patch number and patch name can be shown now in Edit Menu
Better knob acceleration when adjusting EQ frequency in Global EQ menu
In Global EQ menu, Band 2's frequency display and actual frequency don't match – FIXED
https://www.hotoneaudio.com/support/2
Ampero Owners Manual covering FW 3.8
https://hotoneaudio.oss-cn-shenzhen.aliyuncs.com/prod/support/Ampero_Online%C2%A0Manual_EN_Firmware%20V3.8.1619339519978.pdf
