GT-001 tuner bypass mode acts as mute ?...
Started by binbinhfr, March 10, 2018, 08:12:21 AM
binbinhfr
Hi,
I was testing the tuner of the GT 001 and I noticed that the "bypass" mode which is supposed to echo the dry signal to the output, was infact acting like the "mute" mode : no signal at the output (even if I increase the volume of my amp). The "thru" mode works as intended, outputing the wet signal.
Does anyone have the same problem ? Or is it a default of my unit ? (last firmware 1.10)
Thx.
binbinhfr
OK, I found the mistake by myself  ::)
if you use an expression pedal like EV5, even if in your patch the pedal is not used at all (even for volume), when you switch to TUNER, it is activated by default as a volume controller... And mine was connected but at minimal position....
Godd to know for those who could encounter the same problem...   ;D
