Hi,people.I would like to know how to connect gr-55 with Logic Pro X and plugins
Started by Alex Tow, January 04, 2022, 08:32:03 AM
Alex Tow
If using the GR-55 USB, ensure the Roland GR-55 USB driver is installed.
If using "Guitar to Midi" to control midi instrument VST's ensure the GR-55 system midi option for "GUITAR MIDI OUT" is enabled (off by default).
You can use the USB connection for Midi to your computer, check that your DAW software "sees" the "GR-55 MIDI" (not audio) as a midi input device, and the GR-55 Midi is selected to the track using the VST midi instruments.
Alex Tow
Thanks so much for your help.Actually,I found the solution to my topic  in this here https://www.logicprohelp.com/forum/viewtopic.php?t=9407
Nevertheless,thanks!
mknop2013
Hi
I'm a newby on his forum, with GR55 and with midi.
Would you get a tuto to use GR55 in LOGIC as an external instrument fram A to Z ?
Eric
France
You can use GR-55 to trigger Logic AU Instruments , but Logic can not play GR-55 internal PCM sounds
Start at top of thread
