Pyle PTED06 (Medeli DD309) Table Top Drum set / MIDI drum trigger / Sampler
Started by admin, September 07, 2017, 02:26:47 PM
https://www.pyleaudio.com/sku/PTED06/Electronic-Tabletop-Drum-Machine---Digital-Drumming-Kit
(enable CC translations subtitles
https://detail.tmall.com/item.htm?spm=a220m.1000858.1000725.11.4c637810pY07F7&id=525637561152&skuId=3129286064915&user_id=651123949&cat_id=2&is_b=1&rn=c40b08496aa6f6e6fae0c7946c7377f6
https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=https%3A%2F%2Fdetail.tmall.com%2Fitem.htm%3Fspm%3Da220m.1000858.1000725.11.4c637810pY07F7%26id%3D525637561152%26skuId%3D3129286064915%26user_id%3D651123949%26cat_id%3D2%26is_b%3D1%26rn%3Dc40b08496aa6f6e6fae0c7946c7377f6&edit-text=
Same as Medeli DD309
https://www.medeli.com.hk/dd309
http://www.mecldata.com/download/manual/aw_DD309_manual_G08_140828.pdf
Doubles as USB Audio MIDI Interface and has a full General MIDI sound set and tools for User sample uploads  / playback
http://www.mecldata.com/download/apps/
and Hand Trigger sensitivity setting for use with hands (no sticks)
https://www.groupon.com/deals/gg-pyle-tabletop-digital-drumming-kit-5-piece
7 Pads
(touch sensitivity with Flashing indicator)
Display:  3-digits LED
Voices:  310; 128 GM
Drum Kits:  55 preset; 10 user
Songs: 120 preset; 5 user
Demos:  1
Learning:  Drum lesson
Record:  5 songs
Tempo:  30 - 280
Effect:  Reverb on / off
Others:
PC software (Drum Waver Maker, Song Transfer)
Dimensions:  LWH 618 x 383 x 130 mm
Weight:  3.38 kgs (without battery)
The Pyle Tabletop Digital Drum Kit is an all-in-one wonder. Enjoy customizable sound and compact portability with this versatile drumming machine. It's loaded with hundreds of built-in sounds, songs and drum kits -- making each of the seven touch-sensitive drum pads capable of producing a wide range of realistic drum audio. You'll also have the ability to make your own music! Connect the drum kit to your computer -- record, save & edit your drum recordings. Built-in speakers to plays your audio, or envelope yourself in percussive rhythms by plugging in your own headphones. System also includes two digital foot pedals so you can get the real feel of a kick drum and hi-hat pedal. Additional features include the integrated 'Drum Trainer Mode' that's perfect for beginners, 'Hand Percussion Mode', built-in metronome, digital LED display button control center, along with sound configuration adjustments to the tempo, beat, rhythm and EQ settings. The system is also optionally powered, requiring (6) x 'C' batteries, making it convenient for wireless and portable drum sessions. Drum along, or create your own song, with the Pyle PTED06 Electronic Tabletop Digital Drum Machine!
Features:
All-in-One Electronic Drum Kit
Compact & Portable Tabletop Design
Hundreds of Built-in Sounds, Songs & Drum Kits
Make Your Own Music: Connect to Computer & Unlock More
Record, Save & Edit Your Drum Recordings
Drum Trainer: Learning Mode Perfect for Beginners
Connect & Stream Audio from External Devices
Effectively Reproduces Complete 'Drum Set' Sounds
(7) Drum Pads with Touch Sensitivity:
Tom-Toms, Hi-Hat, Snare Drums, Crash & Ride Cymbals
(2) Digital Foot Pedal Controllers:
Hi-Hat & Bass Drum Pedals
Tempo/Beat/Rhythm/EQ/Volume Adjustment
Hand Percussion Mode: Touch-Responsive Pads
LED Digital Display with Button Control Center
*Optionally Battery Powered: Requires (6) x 'C' Batteries, Not Included
Headphone Jack, 1/4'' Input
Built-in Metronome
Includes Drum Sticks
Works for Mac & PC
What's in the Box:
Tabletop Digital Sound Module
(2) Digital Foot Pedals
Drum Sticks
Wall Power Adapter
Technical Specs:
Cymbal & Drum Sounds: 300+
Audio Drum Kits: 65 (55 Preset + 10 Custom)
Musical Songs: 120
USB Input: Type B
Audio Filetype Created: .MIDI
External Device Connection: Aux (3.5mm) Input
Audio Processing Support: 8/16bit, Mono/Stereo
MAX Wav Support Capacity: 16MB
Power: 120V (12V Power Adapter)
Sold as: 1
Weight: 11.3 lbs.
review
https://translate.google.com/translate?sl=ru&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fdigital-drums.ru%2Freviews%2Fmedeli-dd309&edit-text=
