NUX - Cerberus Multi-FX with IR Cab Loader / MIDI
Started by admin, January 25, 2017, 06:57:31 AM
http://www.effectsdatabase.com/model/nux/cerberus
http://www.cherubtechnology.com/
http://www.nuxefx.com/uploadfile/2017/0710/Cerberus%20Manual%20V3.pdf
https://www.thegearpage.net/board/index.php?threads/nux-cerberus-ir-loader.1788585/
https://m.facebook.com/nuxeffect/photos/a.1625552441007679.1073741829.1625536851009238/1887946364768284/?type=3&source=48
https://m.facebook.com/photo.php?fbid=1885248268371427&id=1625536851009238&set=a.1625552441007679.1073741829.1625536851009238
https://translate.google.com/translate?sl=es&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=https%3A%2F%2Fwww.guitarristas.info%2Fnoticias%2Fnux-cerberus-pedalera-para-usar-metodo-cuatro-cables-cargar-irs%2F6969&edit-text=
One of the most promising products of the fair, in our opinion, happened somewhat unnoticed. It was also presented at this year's NAMM , and it is a multi-effect proposal with a certain innovation component, the Nux Cerberus . Although at first glance it may seem like a multi-effects pedal like any other, this proposal of the company incorporates some subtle variations that make it something special . Like the competition, it has modulation of several types, Delay, Reverb, and saturations.
But its main feature is that it has been specifically designed to be used with the four wire method , which is why it has a loop of effects specially designed for it and True Bypass capability in its sections, to try not to alter our base tone . Another especially good detail is that both the distortion and the overdrive are analog .
In line with the idea of ​​integration, we can also control the channels of our amp with the Nux Cerberus thanks to its MIDI implementation. All this combined with the numerous effects with quite high control possibilities (even Kill Dry function for those using parallel loops), and its clear interface (everything works through dedicated potentiometers) make it an attractive proposal, which could become practically the same. Single pedal that we had in front of us to control ampli and effects. Of course, you could not miss a tuner, memories, navigation between banks, stereo output, USB connection and expression pedal output .
In addition, the Cerberus can deliver a signal with digital speaker emulation by IR's (impulse responses). This means that we can also use the footswitch to play connected to the line. The Nux team clarified during the fair that they are currently "measuring the available memory capacities of the device", with the idea of ​​enabling the inclusion of user IR's.
In short, it's a multi-effect with analog saturation, MIDI, IR's load capacity and very compact size: something like if the Nova System of TC Electronic - which also had analog saturation - had an effects loop, emulated output with possibility To charge IR's and would have been smaller. We will see how it turns out to be the sound quality and manufacture of the product once it is on the street but, for the moment, it does not look bad. We must also know the price.
http://www.nuxefx.com/index.php?m=content&c=index&a=show&catid=72&id=272
Effect types
16
Preset memory
32 banks x 4 presets
Display
3-dighta 7 segment LED
Sampling accuracy
88.2kHz/32Bit
Processing accuracy
44.1kHz/32Bit
THD+N
Cerberus Integrated Effects
NUX Cerberus is our flagship integrated Effects / Controller Multi-Effect that transports you to a whole new world of legendary tones.  It's versatile, easy to use, and combines an unusual array of multiple guitar effects without loosing the basic effects in a straightforward stompbox. And the more you gig with it, the more you'll appreciate our carefully thought-out, user-friendly interface.
Front Control Panel:
You get 16 types of effects integrated into NUX Cerberus's 4 effect modules : DELAY, MOD, DIST and DRIVE. And check this out !
1. Both DIST and DRIVE Modules are analogue circuits, making them sound as natural as a tube amplifier.
2. Furthermore, DELAY, DIST and DRIVE modules, offer a variety of Signal Paths / Routings carefully selected to satisfy the most discerning user.
3. Real-Time Tweak-Control.  Need to make adjustments on the fly? No problem, Cerberes lets you--just like a regular stomp box.
4.  UP to 128 presets can be saved into NUX Cerberus's 32 banks; 4 presets are organized to be 1 bank. FOOTSWITCHS:  A/B/C/D recall any of the 4 presets within a bank.  Use the TAP○▲ and CTRL ○▼ to switch banks.
5. Realistic Cab Simulation, with IR loader with 3rd party IR files supported.
Input / Output Panel
Yes!  Cerberus also has plenty of I/O jacks !   So whether you're practicing or performing, NUX Cerberus will always rise to the occasion !
Specification
Effect types  16
Preset memory  32 banks x 4 presets
Display  3-dighta 7 segment LED
Sampling accuracy  88.2kHz/32Bit
Processing accuracy 44.1kHz/32Bit
Press Release: Nux Cerberus
Update Time: 2017-06-21 09:57:59     Author: NUX
NUX CERBERUS
Shenzhen, China, June 5, 2017– Nux announces new effect pedal Cerberus.
Cerberus is a multi-function effect pedal which can be use as 4 cable method or standalone with some extra ordinary features such as inside routing, IR loader, Nux exclusive analog overdrive & distortion and digital effects.
You can use Cerberus as a standalone pedal or you can add your favorite gear into chain with using 4 cable method. Control everything the way you like, you could prepare your setup and control as a stomp box chain or save any combination as a preset and recall by a single click.
We've put together two exclusive analog drive/distortion pedals, brand new modulation, delay and reverb effects, an integrated loop switcher, IR loader, kill dry function, 0 to 20dB volume boost and an accurate tuner into a simple-to-use floor unit. Great tone, ultimate flexibility, easy control, and extreme portability make Cerberus ideal for all players. It also has an additional control switch for the selected functions by your choice.
Analog Effects:          Overdrive (Blues Breaker style)
                                Distortion (Brown Sound)
Digital Effects:           Tremolo
                                Phaser
                                U-vibe
                                Chorus (Analog, Vintage and Modern)
                                Delay (60's, 70's and 80's  ;"60's=Tape Echo, 70's=Analog , 80's=Digital" )
                                Reverb (Spring, Plate and Hall)
Cerberus has stereo outputs and one of them is a dedicated output with speaker simulation for direct connection to mixer or your audio interface, you can simply activate or deactivate (if you are using 2 amps) by pressing Cab Sim button while you using Output 2. Headphone output is cabin simulated and ready-to-play.
Cerberus will be available from official dealers and the street price will be $299 (USD) around in all markets on global.
Main Features:
Analog Overdrive & Distortion circuit
True Bypass (OD/Dist. module)
Buffered Tail Bypass (Modulation, Delay, Reverb)
Inside routing between Overdrive and Distortion
Inside routing between Delay and Reverb
Cabin simulation IR loader
Full MIDI implementation
Sixteen effects
Kill Dry switch
Ultra low latency (in to out 0.68ms - 2.04ms)
Editor Software and upgrade (Via USB)
Stereo output
Cabin simulated headphone out.
If you would like to have more information about this product, please contact Ersin Seker on +86 755 26869866 or send an e-mail to ersin@cherubtechnology.com
http://www.nuxefx.com/index.php?m=content&c=index&a=show&catid=45&id=71
Owners Manual soon here:
http://english.nuxefx.com/mdownload.php?proid=81
Specification
Effect types:  16
Preset memory:  32 banks x 4 presets
Latency:  Ultra-low Latency (In to Out 0.68 - 2.04ms)
Tuner: Built-in precise tuner
AD/DA Converter: Drive section remains analog
Kill Dry Function: Yes
Speaker Cabinet Simulation: IR Loader
MIDI Support: Full MIDI Implements
Expression Pedal: It becomes a volume control before the digital section
Boost: 0dB - 20dB Clean Boost
Control Switch: Can be assign as a Clean Booster, Drive Section Bypass, Mod FX Control, Delay/Reverb Control
Display: 3-digit 7 segment LED
Sampling accuracy: 88.2kHz/32Bit
Processing accuracy: 44.1kHz/32Bit
Cerberus is a multi-function effect pedal which can be use with 4 cable method or standalone with some extraordinary features such as inside routing, IR loader, analog overdrive & distortion and digital effects
Each feature of Cerberus is another reason to own it!
Cerberus is a multi-function effect pedal which can be use with 4 cable method or standalone with some extraordinary features such as inside routing, IR loader, analog overdrive & distortion and digital effects.
You can use Cerberus as a standalone to prepare your setup and control as a stomp-box chain and/or save any combination including routing as a preset and recall by a single click. If you have any equipment you can add your essential gear into chain with using 4 cable method. Cerberus also offers MIDI control to organize your own effect pedals and improve your effects control at the same time.
CerberusFront
We've put together 2 selected analog drive/distortion pedals, modulation effects and delay & reverb effects. All these sounds and effects improvised both from the all-time-classic and newly most-liked gears.
cerberusOD
Analog Effects:
Overdrive (Blues Breaker): Cerberus Overdrive sound is a tribute of 70's Little Wing-ish playing style but it's actually created less than 10 years ago and become one of the most-preferred overdrive sound. Overdrive channel simply take your guitar tone to the next level without adding mid frequencies or any other characteristic that came with the "Tube Screamer style" circuits and provides a transparent overdrive sound. A pedal can be sounds amazing but when you create an effect chain, harmonizing the sound is very important to efficient use.
Distortion (Brown Anger): If you prefer high gain distortion that has a Classic British flavor with rich bass response, thick mid frequencies and a balanced treble response, Cerberus Distortion would be one of your all-time-favorite sound. We also considered compatibility of Overdrive and Distortion channels, whether you use distortion as standalone or combine with overdrive, when you hit distortion switch you will feel the classic JCM touch on your sound.
Drive section has analog circuitry with digital control paramaters and it remains analog, AD/DA converter starts from the MOD FX section.
cerberusMC
Modulation Effects:    Tremolo: Cerberus Tremolo creates real vintage tremolo guitar sounds, it is easy-to-use compact effect but it offers wide parameters for precise effect tailoring.
                                     Phaser: It's warm, organic and rarely-harsh and burnt-orange phaser. From simplicity and warm, tuneful character to sleepy psychedelic swirl, rich with high-end harmonics the Cerberus's Phaser is a pleasure to use from the second you activate.
                                     U-vibe: For the guitarist who thinks the swirling vibes are awesome especially in "vintage" mode, Cerberus's U-Vibe offers a massive swirl, that's true, it's more than "feels the U-Vibe" sound, you can jump on it. We've added most frequented U-Vibe effect into Cerberus, you don't miss it when you hear.
                                     Chorus: (CE - Analog, SC - Digital, ST - Modern)
CE Chorus: This chorus type is from early years of Chorus effect, there is no vintage sound without an analog chorus touch.
SC Chorus: It adds a dreamy chorus sound and creates an ambient guitar tone. That's another alternative chorus if you like digital touch and create and ensemble chorus effect.
ST Chorus: This is the most stereotype chorus effect. From clean arpeggios or strumming, fat drive power chords to spark distortion killer solos, Cerberus ST chorus will fill all the gaps in your sound and enhance it.
cerberusDR
Delay: (60's, 70's and 80's)
60's Delay (Tape Delay) 55ms - 550ms: Tape delay effect is never gets old. We pick a heavy-lift tape echo and shrink to add one of the delay modes in Cerberus. The sound of the 60's Delay mode could create an aged-over saturated repeats (as tape does).
70's Delay (BBD) 40ms - 400ms: This mode can handle all your performance needs if you prefer to use analog style repeats. It has decreased modulation and you could only feel the analog-like BBD sound repeats which is very preferable.
80's Delay (Digital Delay) 80ms - 800ms: 80's Delay is a fantastic sounding, easy-to-use delay pedal. But despite the simplicity, it is the best if you are using any modulation effect already and only thing you need is crystal clear repeats.
TAP TEMPO
All the Delay effects are providing an original sound and each one has its own delay speed range. When TAP TEMPO activated, Time Knob controls the repeat quantize and TAP TEMPO delay range is 125ms - 1500ms for all delay types. But while you tweak the Time Knob, it becomes to the original delay time range to emerge infinite feedback, run-away/oscillation as physical tape echo and BBD delay.
                                     Reverb (Plate, Hall and Spring)
Plate Reverb       : Plate reverb handles anything from a touch of reverb, if your ambience needs are deep, long decay parameters will give you the deepest but versatile and organic reverb sound.
Hall Reverb         : It offers the spaciousness of a well-architected performance hall and all reflections are natural as a studio quality reverb effect.
Spring Reverb    : Based on a tank sound, get the warmth and richness of a vintage reverb unit with Cerberus's Spring Reverb function.
-More Features-
An integrated loop switcher, IR loader, kill dry function, 0 to 20dB volume boost and an accurate tuner into a simple-to-use floor unit. Great tone, ultimate flexibility, easy control, and extreme portability make Cerberus ideal for all players. It also has an additional foot control switch for the selected functions by your choice, you can also connect an expression pedal and it becomes volume control before the digital section.
Cabin Simulation & IR Loader
Cerberus has stereo outputs and one of them is a dedicated output with speaker simulation for direct connection to mixer or your audio interface, you can simply activate or deactivate (if you are using 2 amps) by pressing Cab. Sim. button while you using Output 2. Headphone output is cabin simulated and ready-to-play. It can run any 3rd party IR files as well.​cerberusIRC
-More Features-
Control switch can be assigned as Reverb, Mod FX, Drive Section Bypass or Clean Boost (0dB - 20dB).
MIDI Implement / Global Settings
When you're using any MIDI-compatible pedals and stompboxes they are extremely handy when paired with a rack processors or even guitar effect software. Cerberus is providing full MIDI implementation that you can use and combine with any MIDI supported gear.
Package Weight: 3.0kg (6.61lb.)
Package Size: 40cm x 16cm x 10cm (15.75in x 6.30in x 3.94in)
Nux will release a Cerberus Editor with IR Cab Loader utility  via USB for Win/Mac  - possibly in time for 2017 Summer NAMM next week in Nashville
it will be available here:
OM
http://www.guitarworld.com/gear-news-effects/nux-announces-cerberus-multi-function-effect-pedal/31268
Nux Announces Cerberus Multi-Function Effect Pedal
Posted 06/09/2017 by Guitar World Staff , photo by Nux
Nux has announced its new Cerberus multi-function effect pedal. From the company:
You can use Cerberus as a standalone pedal or add your favorite gear into the chain using a four-cable method. Control everything the way you like; you could prepare your setup and control as a stomp box chain or save any combination as a preset and recall it with a single click.
We've put together two exclusive analog drive/distortion pedals, brand-new modulation, delay and reverb effects, an integrated loop switcher, IR loader, kill dry function, 0 to 20dB volume boost and an accurate tuner into a simple-to-use floor unit. Great tone, ultimate flexibility, easy control and extreme portability make Cerberus ideal for all players.
It also has an additional control switch for the selected functions of your choice.
Analog Effects: Overdrive (Blues Breaker style), Distortion (Brown Sound)
Digital Effects: Tremolo, Phaser, U-Vibe, Chorus (Analog, Vintage and Modern), Delay ('60s, '70s and '80s; '60s=Tape Echo, '70s=Analog, '80s=Digital), Reverb (Spring, Plate and Hall)
Cerberus also has stereo outputs; one of them is a dedicated output with speaker simulation for direct connection to mixer or your audio interface. You can simply activate or deactivate (if you are using two amps) by pressing the "Cab Sim" button while using Output 2. Headphone output is cabin simulated and ready to play.
Main Features: Analog Overdrive & Distortion circuit, True Bypass (OD/Dist. module), Buffered Tail Bypass (Modulation, Delay, Reverb), Inside routing between Overdrive and Distortion, Inside routing between Delay and Reverb, Cabin simulation IR loader, Full MIDI implementation, Sixteen effects, Kill Dry switch, Ultra low latency (in to out 0.68ms - 2.04ms), Editor Software and upgrade (Via USB), Stereo output, Cabin simulated headphone out.
Cerberus will be available from official dealers, and the street price will be $299 (USD).
For more information, write to ersin@cherubtechnology.com or visit nuxefx.com.
https://www.facebook.com/nuxeffect/
vtgearhead
I hope this device works better than their MIDI switcher.  I was singularly unimpressed to discover that one of the capabilities I purchased it for was not actually implemented.
mchad
I hope it can be used as a midi switcher as well. Bypass the effects and switch presets on other pedals. And when you have a grab and go jam use it as a multi effect.
MIDI Assignment and Cab  IR loading capabilities will be revealed After the Cerberus Editor app is available  - I understand August 2017  ETA
see pic of this Cerberus Editor IR Loader App on lower right in pic below
So it does do IR loading. Now is it one IR per preset, or on IR for all presets?
It will be apparent after the software loader is complete and NUX Cerberus  finally  ships mid August
FWIW - The AliExpress seller I bought from on July 7, 2017 was a fraudulent seller  and I'm going through the tedious AliExpress Dispute claim / refund process
Quote from: Elantric on August 04, 2017, 06:11:08 AM
Maybe you should remove the link to Aliexpress that you posted earlier, to save someone else the hassle.
Quote from: sixeight on August 04, 2017, 06:24:22 AM
Done same time you posted
