Katana - MIDI Control Options
Started by admin, January 30, 2018, 12:38:18 PM
rcknrllmn
Thank you all very much, have it working now.   ;D
easelec
#26
I have a Katana 50 and have started (with the help of Gurbz MIDI Designer Pro templates) figuring out how to put together a virtual front panel that can run on my iPad.
I have my basic MIDI connection working (via a Raspberry Pi MIDI/bluetooth router) and have the Katana responding to the sysex I am sending.
I have had a look through the documents about the sysex that the Katana responds to but most of it documents older versions of the firmware. My current questions are:
  • Can Program Change be used to recall the Katana 50's 4 presets (the presets are Bank A: Channel 1, Bank A: Channel 2, Bank B: Channel 1, Bank B: Channel 2)? Sending a PC message seems to always select Bank A: Channel 1 regardless of the PC message being sent). ANSWER: on the Katana 50 PC 0= Bank A Channel 1; PC 1 - Bank A Channel 2; PC 4 = Panel; PC5 = Bank B Channel 1; PC6 = BANK B Channel 2
  • are there sysex messages that recall/select the 4 presets? I found a document that mentions sysex messages for selecting the channel -- but nothing about selecting the bank. ADDED AFTER INITIAL POST: I can used sysex to switch between channel 1 and 2 but cannot figure out how to switch to the other bank.
  • WAH 95-E? Does anyone know the sysex for selecting the Wah 95-e which was added recently?
easelec
Quote from: easelec on August 07, 2019, 08:46:25 AM
I just noticed that Gumtown's FXFloorboard displays the sysex messages it sends. So, I've been able to find answers to my questions.
grinder
Quote from: admin on July 09, 2018, 10:24:12 AM
Those MIDI CC# in the table above will NOT work without the MIDX-20
http://www.primovasound.com/midx_20_page2.html
the MIDX-20 is doing the heavy lifting
Apologies for the question, but I 'm a complete newbie with this (just researching the subject the last couple of days): Does this mean that those CC# won't work with the Katana head without the MIDX-20? Thank you
easelec
Quote from: grinder on October 15, 2019, 10:53:11 AM
That CC# table is for a device (MIDC-20) that translates from CC to the Katana's native sysex. There are documents describing the Katana's native sysex implementation for talking to the amp if you don't have the MIDX-20.
Quote from: easelec on October 15, 2019, 10:59:32 AM
CAUTION:THESE MIDI CC# CONTROLS ONLY WORK WHEN MIDX-20 IS EMPLOYED with KATANA
https://www.vguitarforums.com/smf/index.php?topic=22630.0
https://www.thegearpage.net/board/index.php?posts/25735576/
grinder
Thanks for the quick response guys. I did some more research here in the vguitar forum and I believe I got the idea. So basically either the MIDX-20 is required or the MIDI Bridge for RPI / BeagleBone with a USB to MIDI cable (or maybe a MIDI HAT if it's the RaspberryPi) to connect to a MIDI foot controller.
It 'd be nice if all these MIDI capabilities were directly accessible using the native MIDI port of the head, but I guess that would kill the multi-effects units that Roland/Boss does (eg, GT-100). Who know maybe with the Mkii version.
keithwm
Hi folks, I have just purchased a midx-20. It works fine with my Katana 100 head (but that has midi anyway), it works via the USB.
But: I can't get my Katana 50 combo to respond at all.
Both amps are Mark 1 and I have ensured they are both using firmware v4 from Boss.
I can't get any channel change (I haven't tried CCs yet as that is a different midi board).
I have checked settings and the combo and the head are both a midi channel one and are set for the same patch number to choose amp channels.
Any ideas?
Quote from: keithwm on September 17, 2020, 09:21:59 AM
Any ideas?
PM Codesmart
https://www.vguitarforums.com/smf/index.php?topic=17561.0
CodeSmart
Actually I don't have a clue right now. I only own a head with V4. Can anyone else with this configuration try it?
The 50 should work the same as the 100, does your 50 work with Tone Studio OK? (test if the 50 USB port working)
