GP-10 - Nylon Real Acoustic Collection
Started by Autana, March 24, 2016, 06:14:06 AM
Autana wrote>
New demo for NyRAC by Autana (Carlos E. Arellano)
Smooth Pop style, first solo NyRAC NylonLatin patch.
Second solo electric ovd. guitar, both from GP-10.
AndresOtero
Muchas gracias por el material ofrecido.
Negroescipion
I have checked this patch and is wonderfull¡¡. Thanks for this present. I just have received my new Godin Nylon and whith Boss GP10 this sound is
incredible¿.
Muchas gracias y mucha suerte, amigo.
Saludos desde España.
One question...¿ It is posible to know the paremeters of each effect¿. I´m trying to record midi and I wish to aplicate the same sound to the midi notes..
VGA-7
Quote from: Negroescipion on September 24, 2020, 03:14:14 AM
incredible¿.
Use Boss tone studio, the editor section, and access all paramaters.
Gibson L6S /gk2a , Bradley mini strat  /gk2a VGA-7 amp ,GR-33 , GP-10,SY1K, RMC breakout box, PK5 midi pedals,CM-64 sound module, Oberheim EDP  ,Boss RC-300,Digitech TRIO and TRIO +, Alesis DM5, GX2 Gear Shifter and GKPX-14
If you use GP-10Edit (another FxFloorBoard editor), and load the patch file offline (or with the GP-10),
it can display a text view of all the patch parameter settings.
download here:
https://sourceforge.net/projects/grfloorboard/files/GP-10/
Fri Sep 25 13:40:31 2020
Boss GP-10 Complete Patch Summary
a list of all parameters with-in this patch.
Common***********
[Level Level] = 132
[BPM Tempo] =
[Input GK Select] = GK Set 1
[Normal P.U. Off/On] = Off
[Normal P.U Level] = 100
[Input Cable Simulation] = OFF
[MIXER GK/Model Input] = 100
[MIXER Normal P.U Input] = 100
[MIXER Balance] = 0
Modeling***********
[Modelling Tone] = On
[Modelling Type] = E.Guitar
[Modelling N.S.] = Off
[NS Threshold] = 25
[NS Release] = 20
[String Level 1] = 100
[String Level 2] = 100
[String Level 3] = 100
[String Level 4] = 100
[String Level 5] = 100
[String Level 6] = 100
[String Pan 1] = 0
[String Pan 2] = 0
[String Pan 3] = 0
[String Pan 4] = 0
[String Pan 5] = 0
[String Pan 6] = 0
[E.Guitar Type] = 335
[E.Guitar Volume] = 100
[E.Guitar Tone] = 54
[Fretless Tone] = Standard
[Fretless Sense] = 50
[Fretless Depth] = 0
[Fretless Attack] = 50
[Fretless Resonance] = 50
[Fretless Direct Level] = 0
[Classic Strat Pickup Select] = Rear
[Modern Strat Pickup Select] = Rear
[Telecaster Pickup Select] = Rear
[LesPaul Pickup Select] = Rear
[P90 Pickup Select] = R + F
[335 Pickup Select] = R + F
[L4 Pickup Select] = Front
[Rickenbacker Pickup Select] = Rear
[LIPS Pickup Select] = Rear
[Advanced Single Pickup Select] = Rear
[Advanced Hum Pickup Select] = Rear
[Acoustic Type] = MA28
[Acoustic Volume] = 100
[Acoustic Tone] = 50
[Acoustic Body] = 80
[Acoustic Attack] = 50
[Sitar Sense] = 50
[Sitar Colour] = 50
[Sitar Decay] = 50
[Sitar Buzz] = 50
[Sitar Attack] = 50
[Sitar Pickup Select] = Rear
[Banjo Resonance] = 50
[Resonator Resonance] = 50
[Resonator Sustain] = 50
[E.Bass Type] = Jazz
[E.Bass Volume] = 100
[E.Bass Tone] = 100
[Fretless Tone Type] = Rear
[Jazz Bass Rear Vol] = 100
[Jazz Bass Front Vol] = 100
[Synth Type] = GR-300
[GR-300 Mode] = VCO
[GR-300 Volume] = 100
[GR-300 Comp Sw] = OFF
[GR-300 CutOff] = 75
[GR-300 Resonance] = 30
[GR-300 ENV Mod Sw] = ON
[GR-300 ENV Mod Sens] = 50
[GR-300 ENV Mod Attack] = 20
[GR-300 Pitch Switch] = OFF
[GR-300 Pitch A Pitch A] = 0
[GR-300 Pitch A Fine A] = 0
[GR-300 Pitch B Pitch B] = 0
[GR-300 Pitch B Fine B] = 0
[GR-300 Pitch Duet] = OFF
[GR-300 Sweep Sweep] = OFF
[GR-300 Sweep Rise] = 30
[GR-300 Sweep Fall] = 30
[GR-300 Vibrato Vibrato] = OFF
[GR-300 Vibrato Rate] = 50
[GR-300 Vibrato Depth] = 50
[OSC Mode] = Single
[OSC Volume] = 100
[OSC 1 Waveform] = SAW
[OSC 1 Pitch] = 0
[OSC 1 Fine] = 0
[OSC 1 Pulse Width] = 50
[OSC 1 PW Mod Rate] = 50
[OSC 1 ENV Attack] = 10
[OSC 1 ENV Decay] = 30
[OSC 1 ENV Depth] = 0
[OSC 1 Level] = 50
[OSC 2 Waveform] = SAW
[OSC 2 Pitch] = 0
[OSC 2 Fine] = 0
[OSC 2 Pulse Width] = 50
[OSC 2 PW Mod Rate] = 50
[OSC 2 ENV Attack] = 10
[OSC 2 ENV Decay] = 30
[OSC 2 ENV Depth] = 0
[OSC 2 Level] = 50
[Filter Type] = BYPASS
[Filter Slope] = -12dB
[Filter CutOff] = 50
[Filter CutOff Flw] = 0
[Filter Resonance] = 50
[Filter Velocity Sens] = 0
[Filter ENV Attack] = 5
[Filter ENV Decay] = 20
[Filter ENV Sustain] = 10
[Filter ENV Release] = 2
[Filter ENV Depth] = 10
[AMP Velocity Sens] = 50
[AMP ENV Attack] = 0
[AMP ENV Decay] = 40
[AMP ENV Sustain] = 35
[AMP ENV Release] = 2
[LFO 1 Waveform] = SINE
[LFO 1 Rate] = 50
[LFO 1 OSC1 Pitch Depth] = 0
[LFO 1 OSC2 Pitch Depth] = 0
[LFO 1 Filter Depth] = 0
[LFO 1 Amp Depth] = 0
[LFO 1 Delay Time] = 0
[LFO 1 Fade Time] = 0
[LFO 2 Waveform] = SINE
[LFO 2 Rate] = 50
[LFO 2 OSC1 Pitch Depth] = 0
[LFO 2 OSC2 Pitch Depth] = 0
[LFO 2 Filter Depth] = 0
[LFO 2 Amp Depth] = 0
[LFO 2 Delay Time] = 0
[LFO 2 Fade Time] = 0
[OSC Poly/Mono] = POLY
[OSC Chromatic] = OFF
[OSC Portamento] = POLY
[OSC Porta Rate] = 30
[OSC Porta Mode] = MODE 1
[OSC Synth Hold] = MODE 1
[OSC Low Velo Cut] = 2
[Wave Type] = SAW
[Wave Volume] = 100
[Wave CutOff] = 50
[Wave Resonance] = 50
[Wave Octave] = OFF
[PolyFX Type] = Distortion
[Guitar Volume] = 100
[Distortion Balance] = 50
[Distortion Gain] = 50
[Distortion Colour] = 100
[Distortion Tone] = 50
[Distortion Level] = 50
[Crystal Colour] = 50
[Crystal Tone] = 50
[Crystal Level] = 50
[Rich Mod Colour] = 50
[Rich Mod Tone] = 50
[Rich Mod Level] = 50
[Slow Pad Colour] = 50
[Slow Pad Tone] = 50
[Slow Pad Level] = 50
[Touch Wah Mode] = BPF
[Touch Wah Polarity] = Up
[Touch Wah Sense] = 50
[Touch Wah Frequency] = 50
[Touch Wah Peak] = 50
[Touch Wah Volume] = 100
[Touch Wah Tone Type] = Standard
[Touch Wah Comp] = ON
[Touch Wah Comp Sustain] = 50
[Touch Wah Comp Attack] = 50
[Touch Wah Decay] = 0
Alternate Tuning***********
[Alt Tuning Switch] = Normal
[Select] = Open D
[Pitch Shift 1] = 0
[Pitch Shift 2] = 0
[Pitch Shift 3] = 0
[Pitch Shift 4] = 0
[Pitch Shift 5] = 0
[Pitch Shift 6] = 0
[Pitch Fine 1] = 0
[Pitch Fine 2] = 0
[Pitch Fine 3] = 0
[Pitch Fine 4] = 0
[Pitch Fine 5] = 0
[Pitch Fine 6] = 0
[12 String Switch] = ON
[12 String Select] = User
[12 String Shift 1] = 0
[12 String Shift 2] = 0
[12 String Shift 3] = 0
[12 String Shift 4] = 0
[12 String Shift 5] = 0
[12 String Shift 6] = 0
[12 String Fine 1] = 12
[12 String Fine 2] = 12
[12 String Fine 3] = 15
[12 String Fine 4] = 15
[12 String Fine 5] = 16
[12 String Fine 6] = 17
[12 String Tuning Level 1] = 25
[12 String Tuning Level 2] = 25
[12 String Tuning Level 3] = 23
[12 String Tuning Level 4] = 23
[12 String Tuning Level 5] = 20
[12 String Tuning Level 6] = 20
[12 String Tuning Delay 1] = 41 ms
[12 String Tuning Delay 2] = 41 ms
[12 String Tuning Delay 3] = 41 ms
[12 String Tuning Delay 4] = 45 ms
[12 String Tuning Delay 5] = 45 ms
[12 String Tuning Delay 6] = 45 ms
[String Bend Switch] = OFF
[String Bend Depth 1] = 0
[String Bend Depth 2] = 0
[String Bend Depth 3] = 0
[String Bend Depth 4] = 0
[String Bend Depth 5] = 0
[String Bend Depth 6] = 0
[String Bend Control] = 0
Pre Amp***********
[Amp Switch] = ON
[Amp Select] = Deluxe Crunch
[Amp Gain] = 99
[Amp T-Comp] = 5
[Amp Level] = 60
[Amp Bass] = 43
[Amp Middle] = 61
[Amp Treble] = 86
[Amp Presence] = 81
[Amp Bright] = ON
[Amp Gain Sw] = Middle
[Amp Solo Sw] = OFF
[Amp Solo Level] = 50
[Amp Direct Level] = 0
[Speaker Type] = 4x10"
[Speaker Mic Type] = DYN57
[Speaker Mic Distance] = On Mic
[Speaker Mic Position] = 3 cm
[Speaker Mic Level] = 100
FX***********
[FX Switch] = OFF
[FX Type] = OD/DS
Piing
Quote from: gumtown on September 24, 2020, 06:43:46 PM
Why I didn't thought of that  ???
I made screenshots of all the Tone Studio editor pages before I sold the GP-10, to translate them to the SY-1000  ::)
Thank you
jesusmorente
Hi. Im new here. Thx for accepting me. I have a godin sa grand concert with rmc and have recently buyed a gp10. I wonder if the patches from nyrac will work for nylon strings and if there is another patches out there made for classical guitars. I play mostly flamemco but also son cubano and the main purpose in buying the gp10 was to try to get sthing similar to a tres cubano. Sbody knows how?
Thx and srry for my english and my ignorance
jassy
Hola Jesús, estos presets de Autana son fantásticos para imitar una guitarra española desde una guitarra eléctrica, pero si lo que quieres es un sonido auténtico de guitarra española esto no se acerca al sonido natural que te da tu Godin Gran Concert, ni lo dudes.
Respecto a imitar un tres cubano, prueba con los muchos parámetros de edición que tiene el GP10 para conseguir la afinación de las 3 cuerdas, añadir el efecto de doce cuerdas para imitar el sonido de la doble cuerda y el tono que tiene el tres, seguro que te aproximas.
Quizás puedes utilizar algun preset de los que hay en esta web como punto de partida para editarlo, seguramente hay algún preset de mandolinas o instrumentos que estén próximos al tres para partir de ahí.
jesusmorente
Gracias Yassy. Estoy en ello con lo del tres.
Voy lento porque soy muy malo para estas cosas. Hay muchos matices en el tres que seguramente se pueden conseguir con el pedal pero estoy Verde manejando parámetros y funciones.
El Tres desafina y da falsas notas. Tengo que encontrar donde para poder ajustarlo en el pedal. Ajustar el ataque, donde octava y donde no etc... también creo que tengo que ajustar la señal que dan las cuerdas en cada piezo. A ver como queda, seguiré probando
AndresOtero
Magnifica interetación.
Muchas gracias por este aporte
Aengelantir
Absolutely love this. It'll make the difference in my bossa band.
Gibson L5 CES, Ibanez 2630 Artist + GK-3, Fender Am Strat, Ibanez ST-300, Aria Nylon, Fina steelstring, GT-10, GP-10, Ableton.
VeyG
I would like to know where to download the NyRac patches .
Thank you very much🙏
philjynx
#187
Quote from: VeyG on July 25, 2023, 07:59:32 AMI would like to know where to download the NyRac patches .
The TSL files are on the first page of this thread.
VeyG
I was able to download, thank you. but I have no idea how to insert it in GP10.
Use Boss Tone Studio for GP-10 app (win/mac) download its PDF user manual
Quote from: VeyG on July 26, 2023, 12:07:46 AMI was able to download, thank you. but I have no idea how to insert it in GP10.
You need the correct driver and Boss Tone Studion for windows or macOS
https://www.boss.info/global/support/by_product/gp-10/updates_drivers/
frank97
very good, excellent work. very nice. Greetings from Italy
