New - Boss DD-500 Digital Delay
Started by mchad, July 08, 2015, 02:23:26 AM
Boss DD500 Digital Delay Owners Manual
See attached PDF
thebrushwithin
Now_And_Then
Quote from: thebrushwithin on October 03, 2015, 09:52:50 AM
This is a very nice demo!
That is an outstanding demo. I'd like to find that kind of demo for the SY-300...
thebrushwithin
Yes, it was enough to convince me to order one!
mchad
Copied from The Gear Page:
<Version 2 Newly Added Features>
•Improved A/B Simul mode with more flexible control and input/output options
•Five newly added effects, including vintage Binson Echorec 2, touch-responsive filter delay, and more
•Additional detailed tone-editing parameters such as feedback damp and modulation mode
•More flexible routing options with the new Insert Loop function, selectable EQ insertion position, expanded independent delay connection modes, and more
•Enhanced effects with extended parameters and sound quality refinements, including stereo pitch shifters and overtone effects for Shimmer mode, effect targets for Slow Attack mode, and more
https://www.boss.info/global/products/dd-500/downloads/
https://www.boss.info/global/products/dd-500/support/
Is this actually a firmware upgrade or is it a new version of the same product?
new DD-500  firmware
https://www.boss.info/us/support/by_product/dd-500/updates_drivers/a7b89c2f-4b10-400d-a7cc-f6ffe643e785/
Update history
[ Ver.2.01 ]
Functionality Improvement
Additional display options have been added to A/B SIMUL mode. You can select both MS and BPM options use the [DOWN] / [UP] buttons to switch the screen.
Bug Fixes
The carryover function does not work when receiving EFFECT SW CC from MIDI.
The effects may not be able to be turn on / off when receiving EFFECT SW CC via MIDI.
System error occurred due to parameter setting in PATTERN mode.
Issue fixed where the delay sound sometimes continues to sound when switching banks in A/B SIMUL mode.
Other problems related to effect switching and MIDI reception have been fixed.
https://static.roland.com/assets/media/pdf/DD-500_l_ver200_eng01_W.pdf
That might be worth buying now. Or should I wait for a simular upgrade for the sy 300 delays.
Oh and maybe they'll add an actual gr 300 waveform model to the sy300.
https://www.boss.info/us/support/knowledge_base/206455795/
DD-500: SET UP TAP TEMPO FUNCTION ON AN EXTERNAL FOOTSWITCH.
Back to Results
If you wish to use the TAP/CTL switch for a third Delay preset in a DD-500 preset Bank instead of Tap Tempo, you can use an external footswitch to control Tap Tempo.
To do this:
1. Press EDIT.
2. Use the Up/Down Arrow buttons to select CONTROL.
3. Press EDIT.
4. Press Down Arrow to select CTL1 FUNC:
5. Turn the TIME/VALUE knob to select the TAP option.
6. To determine whether this will be a a global footswitch assignment, or
    patch-based, press Down Arrow until CTL1 PREF: is selected.
7a. If you want the assignment to be Patch based, so it only applies to the patch
     you configured, leave this preference set to PATCH and WRITE the changes
     you've made to the Preset by pressing EXIT and EDIT together, then press EDIT
     once.
7b. If you desire it to affect all patches equally, turn the TIME/VALUE knob to select
      the SYSTEM option, then press EXIT twice.
tonk wrote>
Wanted to give people a heads up that I have set up a GitHub repository for patchsets for the BOSS 500 series pedals. I had previously mentioned it in the DD-500 and its corollary beginner thread, but with the recent addition of MD-500 configurations, thought I'd share it more widely.
The repo can be browsed at https://github.com/gantbd/BOSS, and if you're on a Mac or have git already installed on windows, you can clone it by opening a terminal and running "git clone https://github.com/gantbd/BOSS.git".
Please feel free to submit PRs (if you're so inclined) to improve the content, or reach out if you have any questions.
Cheers!
QuoteBOSS
A repository to contain backups and patches for the xx-500 series of BOSS pedals.
Quote from: Now_And_Then on September 08, 2015, 01:55:46 PM
Boss DD-500 Manual: http://1drv.ms/1i2Awj5  (I looked but I don't think that anyone has posted this link or anything similar here.)
(This was originally uploaded and the link originally posted by "Guitarist1969" at The Gear Page, on http://www.thegearpage.net/board/index.php?threads/boss-dd-500-questions-tips-tricks-and-solutions.1614316/page-2 - so big thanks to him.)
I was very interested in this until I looked at the manual and (as far as I can tell) saw that the LFO waveshape had only sine, triangle, saw. I am still interested but the lack of a square wave, like the Korg SDD3000 or Pigtronix Echolution 2, is a problem.  (Edit: the "square wave" in the Echolution 2 is not actually a square wave. I don't what kind of waveform it is, but I know what it isn't, and it isn't a square wave. This is very unfortunate, as far as I am concerned.)
Kind of disappointing. I will still be looking into this, though. It still seems to be very capable, and reasonably priced.
Describe a case use for Delay with square wave modulation?
acousticglue
Quote from: Elantric on May 11, 2017, 04:32:48 PM
Boss DD-500 Editor for Win/Mac
Boss DD-500 Editor Manual (PDF)
https://static.roland.com/assets/media/pdf/DD-500_Editor_eng01_W.pdf
new Boss DD-500 Firmware ( to support the Editor)
https://www.boss.info/global/support/by_product/dd-500/updates_drivers/b353db72-4436-46b8-8f78-ed8445ed5e99/
How does one access or use the C patch area? It is greyed and cannot move patches to it and make work. Is there a trick to this?
acousticglue
and btw this to me is the single best pedal delay on market I have used, has enough parameters but not a sinking ship of them.
DarthTangYang
#49
Quote from: acousticglue on April 01, 2022, 03:37:56 PMHow does one access or use the C patch area? It is greyed and cannot move patches to it and make work. Is there a trick to this?
I recently bought the DD-500 and the RV-500 but I have never used the editor. Would it be possible to use an expression pedal to control the dry mix?
Boss does claim in one of their product support videos:
"ANY parameter in the DD-500 can be controlled using footswitches, expression pedals and/or the internal LFO (Low Frequency Oscillator)"
Now, I don't know what the "LFO" is or what they mean by that but they do clearly say that "ANY parameter" can be controlled using an expression pedal. Then the dry mix should be no problem, right?
STEREO WET
2 Hughes & Kettner Vortex Black Series heads/ H&K 4X12 cabs Celestion Rockdriver Jr's.
MONO DRY
Orange TH30/Harley Benton 2X12 cab Celestion V30's.
Victory V4 The Kraken
PEDALS
Dunlop CryBaby
Electro Harmonix - Green Russian Big Muff
TC Electronic - Vortex
Boss DD-500
Boss RV-500
