FC300 - Calibrating the FC-300 EXP Pedals
Started by concordal, February 05, 2015, 02:33:39 PM
concordal
Here's a tip from forum member Fusion on the GR-55 board that's useful when calibrating the EXP pedals on the FC-300.
"Put a penny under each side of the pedal so that the pedal travel stops on each penny and calibrate to that range. That way the full up or dwn will for sure be dead on and the system will compensate the rest of the range it is given."
The switch part of the pedals is much more reliable now.  You'll find details on how to calibrate your FC-300 EXP pedals on P.56 of the manual.
