GT-1 - I would like to have the EXP SW assignable...
Started by booh, May 31, 2017, 01:41:51 AM
booh
... to switch more than one effect as once, like with any other switch.
Hi all. I am new to the forum and a new owner of the GT-1.
I am wondering why the EXP SW is not in the list of assignable controls.
Or is there any workaround?
Hmmmmm...
Does seem to be a limitation of the GT-1, no EXP SW in the Assigns.
beatpete
Quote from: booh on May 31, 2017, 01:41:51 AM
There is a crazy workaround however by using (on an assign) the internal pedal, set it to the parameter you need and then select trigger you need (EXP switch) from the menu (INT PDL Trigger). Kind of cool is, you can also select exp pedal min. mid, and max as triggers.
Th major drawback is you can't program a second set os parameters for the exp pedal when it's switched like you can with the GP-10 (EXP1off/EXP1on).
booh
That sounds interesting (and complex at the same time). I have to try it out. I hope I'm able to manage it ;)
