Rockchip SBC Computers
Started by admin, October 24, 2017, 05:38:46 PM
Renegade ARM Computer with USB 3 on Android Linux
The first SBC with up to 4GB of DDR4, 4K, Gigabit Ethernet, and USB 3.0 for the ultimate experience.
https://www.indiegogo.com/projects/renegade-arm-computer-with-usb-3-on-android-linux#/
About
Renegade is our first board to feature DDR4 technology, USB 3.0 capability, and Gigabit Ethernet. This modern and powerful platform shares the same form factor as the Raspberry Pi 3 Model B* minus one USB port. It features both mainline Linux and Android 7.1 Nougat Support. Like all of our boards, it is designed completely with open-market components.
* while hardware form factor is shared, boot and Linux kernel compatibility are not
ROC-RK3328-CC (Renegade) --- AML-S905X-CC (Le Potato) --- Raspberry Pi 3 Model B
Why is this project important?
The Libre Computer Project is a brand rather than a manufacturer. We carefully select manufacturing partners and designs to make sure that the platform as a whole will meet our requirements for open-source support and maintenance. We shy away from proprietary interfaces, vendor lock-in, and "secret saucy" magic because we feel strongly that those things are only redundancies hindering progress.
We are expanding our lineup to cover popular solutions in use today. We want to continue to simplify education, accelerate product development, and facilitate the inception of other technologies. Reducing barriers to entry is part of our mission.
Together with our partners, it is our goal to provide reliable and long-term supported platforms that you can depend on to create even more innovative products and services. We are open to cooperative ventures with companies willing to offer the same level of care and attention to their products throughout its lifecycle.
What operating systems and software images will you have?
Rockchip has done an amazing job upstreaming support for their chips in mainline Linux. Most of the SoC features work out of the box. However, packaging distributions for specific applications is still a lot of work. We are teaming up with the Firefly team and BayLibre to bridge the gap with additional software support. There are so many boards that people buy that end up in a box somewhere unused due to the lack of software support. We are letting you know now that this will not be one of those. We will be bringing software support for Media Center, Retro Gaming, Desktop Computing, and many other use cases.
Where can I find the complete specifications?
You can find the complete specifications for this board on our website www.libre.computer.
How far along is this project?
The product design, initial software support, and testing have been completed by our internal team. Your contributions will be used towards the manufacturing and distribution of the boards. The boards will be available for delivery at the end of December.
We will be providing the following:
Schematic Diagram
Android 7.1 Nougat
Ubuntu 16.04 with Rockchip's Linux 4.4 Kernel and Mainline Linux 4.14 LTS Kernel
https://www.techrepublic.com/article/cheap-but-powerful-raspberry-pi-rival-25-pine-h64-offers-4k-hdr-video-pcie-and-usb-3-0/
Pine64 also announced the more powerful RockPro64. This board features a hexa-core processor, with cores clocked at up to 2GHz, and is available in a version that bundles a dedicated Neural Network Processing Unit (NPU).
The NPU board is targeted at developers who want to experiment with AI and machine learning.
Pine64 says this NPU can accelerate the performance of deep neural network models—such as Inception V3, ResNet-34 and VGG16—by almost 100x, with a peak performance of 2.4 TOPS (trillion operations per second), while also being more efficient than using GPUs.
The RockPro64's powerful on-board GPU can also drive two 4K displays, there is a single USB 3.0 port, a PCIe slot for hooking up fast storage, Gigabit Ethernet, and HDMI.
Again the RockPro64 should run a variety of Linux-based operating systems, including Android, with Pine64 promising to confirm which systems at a later date.
The 2GB RockPro64 board will be available for around $60 and the 4GB version for $79 from March 15th. The RockPro64-AI board, which features the NPU, will be available from August 1st for $99.
RockPro64 specs
System-on-a-chip: RK3399
CPU: Rockchip RK3399 hexa-core processor with 2x ARM Cortex A72 cores up to 2.0 GHz, 4x Cortex A53 cores. RockPro64-AI has a Neural Network Processing Unit (NPU)
GPU: Arm Mali-T860 MP4
Memory: 2/4GB LPDDR3
Storage: eMMC flash module, micro SD card (bootable), 128 Mbit SPI flash
Video: HDMI 2.0 output, eDP connector, MIPI connector & TP connector & backlight supply, DisplayPort via USB type C
Audio: ES8316 audio codec, headphone / mic jack
Connectivity: Gigabit Ethernet, SDIO socket for Wi-Fi and Bluetooth module
USB: 2 x USB 2.0 host, 1 x USB 3.0 host, 1 x USB 3.0 type C port with DisplayPort Alt-mode
Camera: Parallel CSI, 2x MIPI CSI
Debugging: 3-pin serial header
Expansion: 40-pin GPIO header (I2C/SPI/I2S/UARTs/GPIOs), PCIe x4 slot
Misc: Heatsink mounting holes & fan header, power/reset/recovery buttons, IR receiver
Power supply: 12V DC input via power barrel jack
Dimensions: 133mm x 80mm x 19mm
The RockPro64.
https://www.officedepot.com/a/products/6788275/Asus-Tinker-Board-Single-Board-Computer/
verview
https://smedia.webcollage.net/rwvfp/wc/cp/1542312301138_325253c2-22d3-4dfa-8b73-c0fdcd716ca2/module/asus//_cp/products/1492559919283/tab-fb5d2988-2134-46cc-a202-43e3e3b89e9e/9eb2ec90-361e-421a-8778-e4f819ffe852.mpeg.mp4full.mp4
Forum
https://tinkerboarding.co.uk/forum/forum-3.html
The Tinker board is a single board computer designed for SBC hobbyists, makers & IOT enthusiasts. It features a quad core 1.8GHz SoC with 2GB DDR3 RAM, non shared Gbit LAN, Wi-Fi with upgradable IPEX antenna support & color coded GPIO connectivity. The PCB & topology leverages industry standard dimensions allowing for extensive compatibility with a wide range of accessories & chassis.
High performance QuadCore ARM SoC 1.8GHz CPU & 600MHz GPU with 2GB of RAM -The Tinker board features the Rockchip RK3288 SoC with a Mali - T764 GPU and 2GB of Dual Channel DDR3 memory
Non shared GBit LAN, Shielded Wi-Fi with upgradable antenna support – Tinker board features a high speed non shared GBit LAN port for improved performance along with integrated shielded Wi-Fi for robust IOT & network connectivity
Highly compatible PCB & topology –Leveraging industry standard PCB & topology dimensions along with IO and connection placement, Tinker board offer extensive compatibility with SBC accessories & chassis.
HD Audio & HD & UHD video support – Tinker board supports HD audio 192/24bit audio along with accelerated HD & UHD ( 4K ) video playback support*1
DIY Friendly Design – Tinker board features multiple DIY friendly use features including a color coded GPIO header, silkscreen PCB and color coded ZIF tabs
Features
CPU Performance
Using a powerful and modern quad-core ARM-based processor, the Rockchip RK3288, the Tinker Board offers significantly improved performance versus other popular SBC boards. Realizing the growing demands of different builds and projects, the Tinker Board features 2GB of LPDDR3 dual-channel memory. Tinker Board is also equipped with an SD 3.0 interface that offers significantly faster read and write speeds to expandable microSD cards used for the OS, applications and file storage.
Robust GPU Performance & Functionality
Featuring a powerful but energy-efficient design, the Tinker Board supports next-generation graphics and GPU Compute API's. Powered by an ARM-based Mali™-T764 GPU, the Tinker Board's GPU and fixed function processors allow for a wide range of uses, including high-quality media playback, gaming, computer vision, gesture recognition, image stabilization and processing, as well as computational photography and more. Multimedia enthusiasts will appreciate the fixed-function H.264 and H.265 playback support, including playback of HD and UHD video.2
SD Card Read/Write Speed
Tinker Board features SD 3.0 specification support, allowing for microSD card compatibility and significantly faster performance. Faster SD Card performance makes it a preferred solution for everyday computing or for application installation, file access and backup.
Networks Performance
Tinker Board features Gigabit Ethernet, which offers significantly improved throughput versus competitor SBC that are equipped with 10/100 Ethernet.
TinkerOS
A Debian-based distribution ensures a smooth and functional experience, directly out of the box. Whether it's browsing the web, watching videos, or writing scripts, TinkerOS is a great starting point for your next project or build.
Specifications
CPU
Rockchip Quad-Core RK3288 processor
Memory
2GB Dual Channel DDR3
Graphic
Integrated Graphics Processor
ARM® Mali™-T764 GPU
Storage
Micro SD(TF) card slot
LAN
RTL GB LAN
Wireless Data Network
802.11 b/g/n, Bluetooth V4.0 + EDR
Audio
RTL ALC4040 CODEC
USB Ports
4 x USB 2.0
Internal I/O Ports
1 x 40-pin header :
- up to 28 x GPIO pins
- up to 2 x SPI bus
- up to 2 x I2C bus
- up to 4 x UART
- up to 2 x PWM
- up to 1 x PCM/I2S
- 2 x 5V power pins
- 2 x 3.3V power pins
- 8 x ground pins
1 x 2-pin contact pin :
- 1 x PWM
- 1 x S/PDIF
1 x 15-pin MIPI DSI
1 x 15-pin MIPI CSI
Accessories
Passive heatsink
User manual
