Digitech RP1000
Started by admin, February 17, 2018, 07:58:01 PM
https://digitech.com/en/products/rp1000#downloads
https://digitech.com/en/softwares/x-edit-v2-7-0-windows
The control of your sound is imperative. The RP1000 gives you added control to express yourself the way you want. No longer will the lack of control stand in the way of your expression
Your rig. The RP1000 integrates into your amp and with your stompboxes, not the other way around. Featuring exclusive Stompbox and Amp loops, the RP1000 doesn't get in the way of your tone and switches external stompboxes in and out of the signal path like large pro rigs. No longer will you have to do the pedal tap dance, just select your preset and your tone is engaged, just the way you like it.
Your Amp. In conjunction with the external Amp Loop, the RP1000 also features an Amp/Cabinet bypass switch that allows you to turn off the RP1000's internal amplifiers and cabinets so your amp's tone stands alone.
Simplicity of a Stompbox. Popular on the RP500, the RP1000 also features the Pedalboard option that turns footswitches 6 through 10 into stompbox style effect on/off controls.
Documentation
Pdf 17 Safety & Compliance Document-English [298 KB]
Pdf 17 Owner's Manual-German [8.9 MB]
Pdf 17 Owner's Manual-French [4.05 MB]
Pdf 17 Owner's Manual-Spanish [3.34 MB]
Pdf 17 Owner's Manual-English [3.01 MB]
Pdf 17 Quickstart Guide-English [1.64 MB]
Downloads
Windows 17 X-Edit v2.7.0 (Windows)
Windows 17 NetUpdater v1.0.1 (Windows)
Windows 17 RP1000 Driver v2.1 (Windows)
Mac 17 NetUpdater v1.0.1 (Mac OS X)
Mac 17 X-Edit v2.5.2 (Mac OS X (Intel))
Features
Effect switching system offers control over external & internal stompboxes and effects
Exclusive Pedalboard Mode provides on/off  and real-time control to any five RP1000 effects or parameters
Amp/Cabinet Bypass defeats internal amplifiers and cabinets in all presets
Built-in 20 second phrase looper
Built-in expression pedal controls the RP1000's Whammy™, wahs, volume, and other parameters
Built-in chromatic Tuner
Switchable Stompbox Loop for effects switcher control of external stompboxes and effects
Switchable Amp Loop to retain your amp's tone
40 Tone and 40 Effects Libraries
200 presets (100 factory, 100 user)
Over 160 effects including stompboxes, choruses, delays, amps and cabinets
Up to 5 seconds of delay time
24-bit 44.1kHz sample rate
All metal construction
Heavy-duty metal switches for stompbox response
Bright LEDs display program status and effect on / off
Large 10 character LED display for preset name, bank name and tuner
Independent 1/4" Left and Right Outputs
Independent XLR Left and Right Outputs with ground lift
Amp / Mixer switch optimizes 1/4" outputs for amp or direct to mixer connections
Stereo 1/8" headphone output
Cubase LE4 Music Production Software included
Downloadable X-Edit Librarian Software
2 x 2 USB audio streaming
Specifications
Chassis   Durable Cast Metal Construction
Display   Large 8 Character Alpha-numeric and 2 Character Numeric LED Display
A/D Converter   24-bit high performance audio
D/A Converter   24-bit high performance audio
Sampling Rate   44.1 kHz throughout
DSP Section   1 Audio DNA2(TM) DSP Processor
Preset Memory   100 User/100 Factory Presets
Dimensions   19.5" Length x 10.75" Width x 3.75" Height
设备重量   11.5 lbs.
Power Supply   9 VAC = PS0913B (pre Oct. 2011), 9 VDC = PS0913-DC (post Oct. 2011)
suggest download ALL Digitech apps & Editors & Librarians
I expect things will go dark by July 1, 2018
http://web.archive.org/web/20170904111250/http://www2.digitech.com:80/soundcomm/guitar_product_start.asp?productid=252
mooncaine
That's just great.  >:(  I finally buy a Whammy pedal after a year of f* around with the Virtual Jeff whammy bar unsuccessfully on my VG. 6 mos. later, that company's shutting down, too.
What, did Gibson own Digitech, too?
Kevin M
They're owned by US Music Corp. Can't seem to find any info online (lazy search) about them being sold or closing. Maybe info for those in the know!  :-)
Quote from: mooncaine on May 15, 2018, 08:12:18 AM
What's the "Virtual Jeff Whammy bar" on the VG?
Quote from: Kevin M on May 15, 2018, 08:50:19 PM
Thats incorect
They were only distributed in USA by US Music Corp
Digitech is a Harman company  - now owned by Samsung, and is restructuring the brand, terminating all activity at the former HQ in Sandy Point Utah
details
https://www.vguitarforums.com/smf/index.php?topic=23531.0
Crazystrings
Greetings!
Is anyone powering the RP1000 with a battery? I'd really love to run it along with my GR55 when busking.
Fender American Strat 1992 w/GK3
Godin Nylon Multiac SA
Washburn J6 archtop
Taylor 510 Dreadnaught
Taylor  K24ce
Roland GR55
Boss SY-1
And a whole lot of stuff!
